I am pleased to announce the release of a new product, a gang tool holder designed to work with the Tormach Tooling System.
This product is available for purchase at Pure Geometry
This tool holder allows you to use your vertical milling machine to perform lathe operations. It was designed specifically for the Tormach 1100 and 770 milling machines, but should work on any machine in that class. Until you can save up for that lathe you've been dreaming about, this is an inexpensive solution that lets you do limited turning operations on almost any milling machine.
To set up this tool holder, mount it on parallels in your vise, and set the origin to the indicated corner. Configure your tool offsets, and you're ready to run. And you can remove the holder from the vise at any time. The next time you need to use the holder, you already have the offsets programmed. All you need to do is set the origin to the new position and you're ready to run.
Specifications:
* Designed to work with 1/2" turning tools and the Tormach Tooling System.
* Holds 4 turning tools and 3 TTS holders.
* TTS holes are reamed to 0.750" for best fit and alignment.
* Black oxide finish. (Pictures are of an uncoated prototype.)
* Fits the inside jaws of most 6" vises.
* Fits the outside jaws of Tormach's 5" vise.
* Compatible with Tormach Automatic Tool Changer.
* Dimensions: 5.95" x 6.3" x 0.96"
I'm very excited about this product. It's the first product that I have designed for machinists. I've been able to use it on my Tormach 1100 to run production jobs, including making new TTS tool holders. I'm hoping that you find it as useful as I do.
Sincerely,
Frederic Scott
Owner, Pure Geometry LLC
