586,089 active members*
3,842 visitors online*
    May 2012
    Sodick A530D EX20 System Disk
    Greetings to all forum members,my name is Matthew i'm a new member
    I have a problem with my A530D EX 20,i think the system disk is corrupted.
    I want to ask you if someone could send me a copy of system disk
    You would be really nice
    Thank you
    best regards Matthew
    Nov 2004
    164
    Similar to my Mark XI control. I think you will find that there are several versions of the system disk and they must be matched to the proper version of the EPROM chips that are in your control board. You will probably have to find someone with the exact same version as you or at least has the same EPROM chips. Otherwise you might have to call Sodick to get one.
    Also the 720KB disk drives in the Japanese NEC computers fail sometimes and they are hard to get hold of as they are special. You might want to put your system disk in a regular desktop PC (Windows XP or older) and see if it is readable. There might be nothing wrong with it.
    Once you get your problem resolved, It is a good idea to get a bitwise image of your system disk as they fail frequently and are finicky. I use a program called DiskFactory to create new system disks from my saved image for my Sodick.
    May 2012
    Thank you jmullett for your support, i think will call Sodick
  1. SODICK A530D EX21 4-AXIS
    By systronic in forum Waterjet General Topics
    Last Post: 10-09-2019, 11:08 AM
  2. Sodick A530D flush Pump.
    By rocco110 in forum EDM Discussion General Topics
    Last Post: 10-18-2011, 02:02 PM
  3. Sodick A530D EX21 E203 Memory cleared?
    By edmengineer in forum EDM Discussion General Topics
    Last Post: 07-08-2010, 09:34 AM
  4. Sodick A530D DNC Setting need help
    By Surjit in forum EDM Discussion General Topics
    Last Post: 05-26-2010, 11:44 AM
  5. M32 System Disk
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 01:25 PM
