586,114 active members*
3,125 visitors online*
    Dec 2011
    Home switchs on the Z
    Hey guys, im in the process of adding a router to my CNC plasma table to allow me to cut plastics....
    question, how do you guys do the home switchs on the Z? With the plasma the Z plate is movable by about 1/2 inch......it uses a touch-and-go setup, where the torch goes down till it touchs the material, which then the z plate moves that 1/2 inch, it trips a switch, then it comes up a pre-set amount to keep the torch at the proper height.
    Of course with a router you wouldnt want the Z to be able to move, so how do you guys do the Z home switch since you deal with different material heights?
    --John
    Z home switch is at the top of the Z travel.
    We usually zero the Z axis to the top of material, either manually or with a touch plate.
    Home is Z zero in machine coordinates, and the part Z zero is in work coordinates.
  1. limit and home switchs...
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-08-2012, 08:58 AM
  2. Part Home vs. Machine Home
    By Mihelich in forum G-Code Programing
    Last Post: 06-07-2009, 07:56 PM
  3. limit switchs
    By lorena in forum Torchmate
    Last Post: 04-04-2009, 04:15 AM
  4. Home again Home again Jiggety Jig. Well Not Just Yet!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-19-2008, 02:58 AM
  5. home&limit switchs?
    By automatic in forum DIY CNC Router Table Machines
    Last Post: 12-31-2007, 11:02 PM
