586,052 active members*
4,055 visitors online*
    May 2012
    Okuma OSP 5000L M19 Code
    We recently bough a used Okuma LB15 with Tail stroke with OSP 5000L . The machine was supplied with a Collete we wish to replace it with new hydraulic chuck.
    But the spindle is not getting locked. We tried to use m19 command even with C
    M19C0 / M19C270
    But getting Alert 472 of Spindle
    We tried to check it in manual but no luck can any one suggest any other way we can lock the spindle so that we can at least change it to chuck.
    This is first time I am using Okuma OSP
    304
    It has been a long time siince I ran that machie but it never had a spindle lock. The best you can do it put the spindle in LOW RANGE, I forget the code (but remember that problem), and that will help a lot.
    May 2012
    RE: Okuma OSP 5000L M19 Code
    Thank you for your prompt reply. Yes its quite old machine and people tend to forget the codes not used often. You mentioned it to take the machine in lower range. Are you talking about Spindle Gear Range.
    My Okuma LB 15 is having Two light M41 & M42
    Do you think i should use M41 / M2 or M40 will solve the problem. Also do i need to specify the speed or any other perimeters
    M40 Spindle gear Range Neutral (got it from the Net)
    M41 Spindle Gear Range 1
    M42 Spindle Gear Range 2
    Feb 2009
    6028
    No spindle lock on that lb15. Just command an m41. That's about as good as you will get. M19 was only an option, and not on most lb15s.
    Aug 2011
    2517
    if you have C axis, engage C with M110 then clamp the spindle using M147 (unclamp is M146, M109 is C axis off)
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  3. NA code in Okuma program
    By emsee in forum Okuma
    Last Post: 08-16-2011, 01:57 AM
  4. v22 won't post correctly to Okuma OSP 5000L
    By NJC in forum BobCad-Cam
    Last Post: 12-21-2008, 03:16 PM
  5. How to end code on an LC-10 ? Okuma
    By karlis_m in forum Okuma
    Last Post: 08-19-2007, 10:42 AM
