Can anyone help me please?! I contacted my supplier and they said my machine could be converted to the MPC6515 Controller and then I could use LaserCut 5.3; In my mind I thought this was a simple process, however it has turned out to be a little more complicated. I have attached photos of my current controller and the new controller; My difficulty is what wires on the old controller actually are!?
I know that it needs to be completely disconnected and removed, however I would like to label each wire with a Name!
I have also attached a PDF sent to me to help me, if you believe that has the answers please let me know!?
The PDF says I must use a 24 Volt power supply, I will need to get one as my current supply is 5 volts.
Also the MPC Hardware manual towards the back shows what wires go into the new board, I include it here so that it may help the knowledgable to help me. Thanks in advance, Amos
