586,121 active members*
3,546 visitors online*
Results 1 to 17 of 17
    Aug 2009
    26
    Waterjet cut programming
    At my work we run a waterjet, and mainly do thing parts on it (chromoly .032" to .125"), and we often try to cut holes to size but being picky seeing as its aircraft stuff we often have problems with the small "gouge" left at at the leadin.
    The machine is a Techni machine, and all programming goes through their own software, and its a bit of a pain, especially seeing as leadins etc are all placed by hand. You can however import NC code.
    say on .040" material, how are people programming to cut say 1/4" holes? Straight lead in, curved ?? What about the feedrates, i know our machine speeds up and slows down etc as it moves into radii/straights.
    The goal is to program it in mastercam with parameters for such things so its more defined and standardized - and then nested - the machine provided nesting functions suck!
    Jul 2012
    This is my first post here on CNC Zone and I came across your post. I'm looking for similar info as you. Not sure how your doing with Mastercam for programming. I'm in a similar situation with a Techni waterjet. Very unhappy with their software, doing manual leadin/out and nest is really bad alone with about everything else. No better luck with cut quality either. Mfg's answer is to slow it down but now we lost our competitive advantage and still can't cut a round hole. We are really struggling to making good parts. Have over 12 years experience with a different brand waterjet so this turned into a real setback to say the least.
    Aug 2009
    26
    Hey mate
    Glad to hear I'm not the only one disliking the "softec" software that runs this machine.
    I was under the impression that the actual waterjet side of the system (being all KMT gear) was quite good and naturally the cut quality comes down to pressure, garnet grade and rate, and cutting speed.
    I've found that even on say .100" chromoly having to cut on "extra fine" with the speed at 30% or something to try and eliminate the taper, but we've just lived with the fact theres a taper and the quality guys have to accept that.
    in regards to the leadins/outs etc it's a real pain and to be honest I'm sick of it, I'd rather have full control over the machine turning on/off and speeds etc. Lead-outs have an automatic speed that is really really low which leaves a mark on the edge due to the kerf getting larger.
    we usually cut quite slow so prefer the lead-out to continue at the same speed, which you have to change manually, rather than it just using the default cut setting. Their response was people usually dont run lead-outs on thin material. If you dont use a lead-out the machine slows down coming to the end of the cut, so the kerf gets larger, and then when it stops there's a delay after the end of the line/arc and it turning the cutting head off. This also leaves a mark.
    Programming in Mastercam was somewhat useful (templates for lead-in/out settings, using extend/shorten to create tabs that should be consistent, nesting) but we were importing into Softec, so it was still controlling the speed. I have toyed with trying to bypass Softec, at times starting the cut, pausing it and manually changing the g-code but this seems like a really difficult way to go as softec is always going to have to be there.
    Their software does handle a lot of things and makes it "easy" in a WYSIWYG way, but is really frustrating at times and they dont really seem to "get it" when you enquire about it. I have to admit though we get that with our Router supplier too so its not like they're the only ones!
    Attached are the lead-in/out settings I was playing with on .100" chromoly.
    Feel free to bang me a PM, good to know of somebody else running one of these things, and waterjet in general.
    Aug 2009
    26
    Just googled you guys, you are the same guys making the knives etc for people?
    I notice in the photo you guys might have a FARO also?
    Just to add to the above, waterjet is only a minority of the work we do, we manufacture aircraft assemblies so its 95% aluminium and we route the parts.
    Due to that not much time is invested in the machine, so alot of the time we just put up with it. The biggest aspect of trying to program in mastercam was to make things more consistent, quicker to program, and the nesting ability, as being able to nest up sheets and run it big batches is the only way to keep the efficiency up, even though it spends most of its time idle.
    The machine is possibly going to be sold off, and to be honest, that doesn't bother me - I'd rather have a turret punch or a much better router (HAAS GR-712?).
    Jul 2012
    Glad to hear your response.
    Yes, I have a few knifemakers I blank part for but the majority of work we do is also in aerospace field. We do a lot of thin Ti, Hastalloy, Aluminum etc.
    We mainly waterjet and just changed from another mfg machine to the Techni. They did a big oversell job on us with the machine capabilities and we are very in the performance disappointed to say the least. Our 12 year old machine would cut circles around the Techni and the circles would be round. We figured we would try to start using Mastercam since the Softech software was so error prone.
    I'll PM you so we can communicate directly.
    Jan 2007
    Hi
    I am working with high precision waterjet cutting machines and have been using IGEMS software for many years without beeing dissapointed once. See igems.se for more information.
    I guess they can provide you with the information you need and postprocessors for your machines.
    Jan 2012
    14
    Just thinking out load. How about you draw a 1/4" circle with spiral lead-in and lead-out. Use the center as the "insertion point", zero point. This will help with the hole's placement. This way, your WJ will cut from the lead-in to lead-out as one line, non stop.
    Do the same for any hole sizes you need and save each as a WJ "object" for future use.
    BTW we are using Techni WJ systems and the software you are using looks very different to what we are using. Toolpath reminded me of MultiCam CNC routing tables. FYI I am located in OZ not USA.
    Aug 2009
    26
    Quote Originally Posted by Learner2 View Post
    Hi there,
    The picture I posted it from Mastercam.
    Toolpath is what we use on our Multicam routers.
    We use the Techni software with our waterjet, how do you find it?
    We are running version 4.65.
    Glenn
    Jan 2012
    14
    Quote Originally Posted by glenneaux View Post
    So that I was right. I still have a 4x4 Multicam in my back shed.
    We are running V4.200.69. I find the software to be full of bugs. A lot of the function have no shortcut keys assigned. The "Standard Object" is not editable and can't zoom to select the insertion point. Long list.
    Basically we only use it to do basic programming and cutting path generating. We are using AutoCad to draw and the import it into Softec to finish it off.
    BTW I just noticed you are in OZ too !!
    Jun 2005
    46
    Hello, have you tried SheetCam? We have used it for several years without any issues. Very east leadin/out, layer control for inside/outside cutting, ect...
    Best Regards, Ron Boeser
    Jan 2008
    66
    I program 4 Flow machines with "Dynamic" (taper-compensating) heads. My prior experience was on an older non-dynamic Flow waterjet.
    WJ manufacturers suggest arc leads for some reason. Don't use them. Try straight in, straight out. To be specific, if a radial line is 0°, we use a 50° lead in and out on thinner material, 10° on thicker material. Also experiment with over-travel (lead-in enters hole at 12:00, lead-out exits hole at 1:00, hole is cut clockwise). Under-travel is also an option.
    Our experimental part program is attached (units in inches).
    We are now programming with Hypertherm's Pronest. Lead styles are configurable via an excel spreadsheet - you can assign a different style depending on hole size and thickness.
    Attached Files Attached Files
    Patrick Brewster
    Nov 2012
    When running most jets on the best lead in is angled with an arc out this allows for a small overlap and a slower lead out on your arch section this will eliminate the tit on the part, with thinner materials if you have global over ride function you can use it for a more consistent feed rate and adjust your acceleration percentage rate to get rid of a tit or a nick at the end of your cut.
    Nov 2011
    28
    We run a Wardjet ZXL-2543 using IGEMS to write and Ikuhlu to run the jet. The software allows absolute control over virtually everything. I have been running this jet for just over a year now I have no complaints with this software at all, very user friendly, quick, and easy to use!
    Jun 2013
    We just bought a new Techni Waterjet a few months ago and are very happy with the software. We have the beveling head option and programming it is incredibly easy. I have many years experience running Flow systems and the Techni software is much easier. The lead ins, compensation and nesting are all automatic? not sure what he was saying in the previous post. We are running version 4.414.18 and seems to be very stable. We couldn't figure out how to program a complicated part but Techni had no issues helping us out over remote support.
    Aug 2009
    26
    Quote Originally Posted by Flyinsqurl View Post
    Yes the software has automagic functions for most things. The nesting sucks big time.
    I don't always want it to put lead-in's on sharp corners or radiuses, i want to be able to place a point or slide the start positiong around the contour. I want to be able to key in a lead in length and angle and have it as a template so its set and forget.
    I've been caught out before rotating parts - either using the "set orientation" function, or the "rotate" function, where it will cut the wrong way around an arc. Simulation it works fine but when you run the machine (Cut or dry run) it goes the wrong way around the circle.
    All of this depends on what sort of work you're doing.. If you're cutting thin aircraft parts from 4130 it becomes a pain, but when we do 3mm commercial jobs that are welded i just use all of the automatic functions and have no problems.
    Personally at my work we don't have much use for the waterjet, it actually sits idle most of the time.
    Jan 2012
    14
    This is where you have to use another CAD program to do the "drawing". The software is basic but functional enough. I am like you happy enough with the support from Techni, so far.
    May 2015
    Re: Waterjet cut programming
    Well, I am working for the waterjet cutting machine parts, if anyone need the fine waterjet nozzles or other accessories, please contact us. Thanks!
  1. Waterjet cutting machine promotion of JETE WATERJET
    By livemott in forum News Announcements
    Last Post: 09-25-2011, 03:25 PM
  2. Someone with a waterjet
    By Trell in forum Waterjet General Topics
    Last Post: 04-16-2011, 05:30 AM
  3. Looking for a 2d dxf for waterjet
    By bullittgt450r in forum Community Club House
    Last Post: 11-16-2009, 07:04 PM
  4. Replies: 0
    Last Post: 10-13-2009, 03:01 PM
  5. diy cnc waterjet?
    By FireFghtr in forum Open Source CNC Machine Designs
    Last Post: 08-05-2007, 05:16 AM
