Hi everyone!
I'm currently setting up my G320's and have read in the installation notes, that you need and Oscilloscope for proper tuning. So I borrowed one. At the encoder testing section the notes say: place the probe on the test point and the ground clip to the blue capacitor ground lead. This is clear. But, at the Gain and Dump section it says: use channel 1 on the test point and channel 2 on the DIR input. Set trigger to normal, trig source to Ch. 2. trig edge to +. Where do I put Ch .2 ground? To the same place, blue capacitor gound lead? Do the same setting (2 volts/cm vertical, 1 ms/cm horizontal) apply to this measurement also? Has anyone done this before?
Any help would be greatly appreciated.
Giorgio
