586,036 active members*
3,626 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processors > Need Postprocessor for Morbidelli author 503
Page 1 of 2 12
Results 1 to 20 of 22
    Dec 2009
    Greetings all,
    We have a morbidelli Author 503 Wood cnc.
    It is shiped with Aspan 6.2 and running perfectly with the shiped cnc programs
    Now we want to create some programs of our own and having a slight problem.
    The CNC controller (tria ) understands only pgm files.
    We bought Vcare so we could make some new drawings and cnc programs.
    ( we just dit not know that there needs to be a postprocessor, never heard of it )
    Is there someone who has a postprocessor file in use with Vcare pro and wants to share it, so we can run our cnc ?
    Geetings
    Adriaan
    May 2004
    4519
    Contact the Vcarve software people by email and ask for assistance.
    Oct 2011
    You should be able to load programs with a .txt extension. Been a while since I've run this machine though and remember it being a pain in the ass to format so the machine would read it. Once you open the txt on the machine you can save as pgm. I think what I ended up doing was saving the gcode commands as a text file, and had to manually type out the header at the machine. It took a good bit of trial and error, but I did manage to load a txt file. The morbidelli post processor should work with editing, the file then just has to be saved as .txt.
    Sep 2008
    13
    Very old thread but Aspan has all you need the post processor is included
    Drawing is constructed in the CAD section
    Gcode is constucted & written to .pgm file in the CAM section
    Hello Adriaan,
    we use the sheetcam (SheetCam homepage program. It works fine but there are some steps to do. But there is a forum woodcnc where we take some help.
    In sheetCam you can import .plt .dxf .svg files.
    There is a postprocessor SCM V1.7.3 with following explanation
    Post processor for machines of the SCM-Group
    Code generated can be adjusted to Tria 4000-7500, Xilog3 and Xilog Plus
    Author Herbert Wols
    use the following Postprozessorparameters for arc creation
    ArcTol as Arctollerance in percent of the arc radius (0 turns arccreation off)
    ArcAng as maximum Angle between two moves combined to an Arc
    ArcPro as maximum length proportion between two elements
    ArcNum as minimum number of elements needed to create an Arc
    horizontal drilling with the tool 99999
    After the generation of the G-Code you must translat in the .pgm program as Tria7500 file. This is done by the DOS program cnv75new.exe After the creation of the .prg file we transfer it with the Kermit Download programm to the machine.
    If you need more help please ask me.
    My problem is t to make the convertion more automatic, but this is with the program winxiso possible. But there is always a format error on running in the morbedelli firmware.
    Greetings ChristophAttachment 181968
    Nov 2014
    8
    Re: Need Postprocessor for Morbidelli author 503
    can someone give me a help
    my company hava a author morbideli 503,and we have a problem with him,they bought the machine in an unknown state,the machine was dead,I made software, and configure PLC,after that machine start the walk,but she doesent work anything,i made a program for driling in the software ASPAN but nothing happend,the machine show me on the monitor that everything is ok but doesent work,after that i see on the working head something missing, i dont know what,if someone had this machine maybe can tell me what is missing,i have 2 cable with 29 wire one with 17 and another with 12, and 4 el.ventils ,pleaseAttachment 255614 help,sory for bad englishAttachment 255612Attachment 255616
    Nov 2014
    8
    Can you help me, a need a picture of working head,from top side, i had the same machine,but my machine doesent work,yust walk,send me please picture of working head from top ,my machine has one part missing,i had 29 wires free and 4 el ventils
    sory for bad englishClick image for larger version.
    Sep 2008
    13
    I have sold my Morbidelli. It was A502 but very similar to A503. I think what you need are technical circuit drawings and these would most likely be held by a Morbidelli technician not an end user. I think you need more than just photos.
    I take it that the 29 wires have been disconnected at the router head. Both the main router heads and also the drilling modules.
    I also take it that the machine sizes OK.
    If you create an Aspan program with just instructions to move (no routing or drilling) does the machine perform as per the program instructions?
    I tried a private message to hasib-cnc but PM's disabled
    regards
    Greg
    Nov 2014
    8
    thans for the reply,do you have anything of this mashine, i dont have support from tehnician,and they dont want to came help,i dont know what to do,if i know how that look i can bought,anything is helpfull,please help,thanks
    Aug 2014
    13
    Hello Christopher,
    I know this is an old post, but would you happen to have a copy of this " postprocessor SCM V1.7.3 " for a Morbidelli Author 213.?
    My problem is that I canot generate a working .PGM file that the A213 can read. I keep getting the error" Invalid File Format".
    I have searched all over the internet and nobody seems to be able to assist. I Also use Kermit to transfer files and it is quite simple to edit the DXF files in Alphacam.
    Mat
    HI Christoph, I have a A504 and use Winxoso to convert from sheetcam .txt file to pgm, I have the same firmware problem importing the file into the machine? did you manage to resolve it?
    If I type it in it runs beautifully but automatic input not readable?
    kind regards
    Adrian
    Hi Mat, did you win with the SCM v1.7.3 PP? I have the same problem, I use the Winxoso one but have a prolem with the Morbidelli reading it? It will run when typed in as is?
    Aug 2014
    13
    @Rocketworks
    WinXISO does not seem to work for these old TRI7500 ... I use a very old converter called CNV75NEW.exe to convert my files from CAD/CAM to .PGM that this old NC can read
    Send me you email address via pm then I'll send you the file
    Smile Re: Need Postprocessor for Morbidelli author 503
    Thanks @auckcabs you're a star I got a copy of cnv75.exe from a forum member, mine is a 504 with Tria 7500 controller 1998. I'm using sheetcam with Xilog post processor is that correct? then what file extension do I use? do you mind sending me step by step instructions thanks [email protected]
    Thank you too much @auckcabs , I hope you send me that program to test, I have a Morbidelli U550 withTria 7500 Controller, and I've been time ago searching for a converter that converts CAD/CAM files into PGM.
    I've tried WinXIso, but the machine controller says that the file is not supported.
    So please send me the software CNV75.exe, and thank you [email protected]
    Apr 2013
    hi every body how are you
    i have Morbidelli author 504 with tri 7500 controller
    year 1992
    i use artcam for design
    i wont converts CAD/CAM files into PGM
    please send me the software CNV75.exe on my email and thank you
    [email protected]
    Has anybody manged to get CNV75.exe working on windows 7?
    Apr 2015
    Hi auckcabs, could you possibly send me on the CNV75NEW.exe. i have a 503 and need a program to convert cad to pgm. Would be really helping me out.
    Jan 2016
    hello auckcabs you would ask if I can send the CNV75NEW.exe converter, I would greatly appreciate it. I have an author 213. thank you very much. [email protected]
    May 2015
    hello auckcabs you would ask if I can send the CNV75NEW.exe converter, I would greatly appreciate it. I have a machine with TRIA 7500. thank you very much. ltrullen@gmail.com
Page 1 of 2 12
  1. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  2. Morbidelli Author 213
    By feechl in forum Commercial CNC Wood Routers
    Last Post: 01-30-2018, 08:51 PM
  3. Morbidelli Author 344
    By tyretochka in forum CNC Machining Centers
    Last Post: 05-19-2012, 06:32 PM
  4. Morbidelli Author 636 top
    By mwatkinson in forum Commercial CNC Wood Routers
    Last Post: 05-11-2010, 10:52 PM
  5. morbidelli author 504
    By msahin2012 in forum Commercial CNC Wood Routers
    Last Post: 05-19-2009, 01:06 PM
