586,082 active members*
3,772 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > HobbyCNC Driver board failure?
    Apr 2007
    I'm no expert on these so I thought I'd come here and ask.
    I have a HobbyCNC Foam Cutter board Rev 1.
    One stepper motor on my foam cutter, has failed and another works
    intermittently. Something on the board has gone as I can swap the steppers to a different output and they work fine.
    What would my next steps be to Investigate or repair?
    It's not the computer, stepper motors or parallel cable as they all work fine.
    Matt
    Mar 2007
    2083
    Hi Matt
    have you contacted Hobbycnc ?
    they should be able to help you with fault finding
    I've don't know any thing about your board
    but the hobbycnc pro board for instance
    has a circuit that detects the step signals
    this circuit switches the reference voltage to the SLA7078
    from a level that disables the motor drive (>2V) when its not receiving step pulses
    down to a lower voltage that sets the motor current when the motor is being stepped
    (this circuit is based on the IC manufacturers data )
    it could be useful to download the data for the IC's
    used on your board
    then look for any difference in the voltages needed
    to enable the driver IC's
    John
  1. HobbyCNC Driver Board Not Working
    By Barefooter in forum Hobbycnc (Products)
    Last Post: 02-12-2012, 09:56 PM
  2. Hobbycnc ez driver board + Mema 23 at 5v each?
    By MadKad in forum Hobbycnc (Products)
    Last Post: 08-08-2008, 10:58 PM
  3. Emcotronic driver board failure
    By Adee in forum Stepper Motors / Drives
    Last Post: 05-13-2008, 05:42 PM
  4. SLA7078mr driver on Hobbycnc pro board
    By vulcom1 in forum Hobbycnc (Products)
    Last Post: 01-31-2008, 11:36 PM
  5. Hobbycnc or Xylotex driver board?
    By Oldboy in forum Hobbycnc (Products)
    Last Post: 12-01-2007, 09:06 PM
