586,111 active members*
3,522 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > machine stutter during surfacing
Page 1 of 2 12
Results 1 to 20 of 21
    Apr 2010
    260
    Our VF3 is doing some surfacing and it seems to be having trouble smoothly cutting the surface of a part. It has a stutter between each block of code, like it is stopping then starting each line. Is there some setting/parameter that I should look for to help smooth out the motion?
    www.machmachine.com
    Mar 2010
    1852
    Is this a brand new problem that you have never seen before? How long have you run the machine?
    Mike
    Dec 2008
    717
    You can control the accuracy of the machine in the machine settings (or with G154). See the manual for the factory spec and make sure it isn't set too high (or small in this case). Setting it to .005" or under will cause the "exact stop" type of situation when surfacing.
    Also, depending on your programming software, you can filter the toolpath and add arcs when it can and that will help the control process the information faster and the drives to be able to move smoother.:banana::wee:
    Tim
    Apr 2010
    260
    currently setting 85 is set to 0.001. Should I increase this to 0.005?
    I dont ever remember this happening before with this machine. So I am wondering if a setting was changed
    www.machmachine.com
    Dec 2008
    717
    I think it comes from Haas set to .020" and the finish set to "Medium"
    Tim
    Apr 2005
    713
    Yeah, .001 is waaaay off. Default should be .025.
    Try this in the heading of your program: G187 P2. E0.025. Those are the default settings and should get you going.
    May 2012
    Setting 85 is currently shipping from the factory with a default of .050 Although this is called "max corner rounding" it is an algorithim and not a tolerance as many assume. Good luck.
    Dec 2008
    717
    Quote Originally Posted by CNC MI View Post
    Agreed. My statement of it "controlling the accuracy" was mis-leading...which is why I called it the "exact stop" type of situation.(jerky motion vs smooth motion)
    It will, however, tend to take shortcuts when given a large number though so in reality...it can cause accuracy issues. I have seen this with the older machines so I leave the number VERY small unless just roughing.
    Tim
    Apr 2010
    200
    Quote Originally Posted by WallyL7 View Post
    +1 on that.
    I used to machine plastics a lot. The limiting factor on how fast we could surface was the tolerance we set in setting 85 (or the G187 command value). Too high a value and we'd get inaccuracies or small gouging in the parts. Too tight and the machine would stutter like you describe. We had to find the right blend of setting 85 and the feedrate to get the results we needed.
    I also assume you are running the program from in the controller's memory and not from DNC, a floppy, or a jump drive, right? If not, then you could be hampered from data starvation as the controller needs more code faster than the connection can deliver it. The symptoms are the same as yours. It has happened to me before when surfacing aluminum and plastic.
    Apparently I don't know anything, so please verify my suggestions with my wife.
    Apr 2010
    200
    One more note:
    We had a couple VF-3's that would retain the values input in a G187 line for subsequent programs even though it's not supposed to be modal. For example, we would run a roughing program with a G187 E.025 line (no P value in older machines). If we ran a finishing program next, then we would have to make sure that there was a G187 E.002 line at the end of the program or we'd get crappy finishes. I ended up changing my post to put it in every footer.
    Doesn't seem to be a problem on my 2007 machine though.
    Aug 2010
    579
    Haas Factory Support
    Please make sure that High Speed Machining (Parameter 315:4) is turned on. Ensure your G187 values are correct and being used.
    Ken Foulks
    I am running into this same issue during both a 'HSM' roughing tool path (~100 ipm, lots of small moves) and also 3D surfacing at 80 and 120 ipm using a 1/2" ball end mill (7500 rpm spindle). I turned on parameter 315.4 (HSM) for my trial 200 hrs, and it definitely helped. I'm a bit disappointed though since I didn't think I'd need to worry about the HSM option until higher feed rates than I'm working with.
    I am running the programs from a USB thumb drive, since I couldn't stomach Haas's upcharge for more than 1MB memory. I ran a small portion of the tool path from the controller and noticed no change in speed, so I don't think the transfer speed from the thumb drive is causing issues.
    Mar 2008
    638
    I have had the same problems. I worked around it by the previous poster's ideas to play with the default smoothness/corner rounding settings. I ended up leaving them at the factory setting (.05 and medium) and changing my feeds and, more importantly, changing my toolpaths in my CAM system. Found that numerous settings in CAMWorks worked better than others. If you use CAMWorks, I can go into it deeper.
    Aug 2009
    235
    +1 on HSM
    When I got the volumill module for GibbsCam I noticed the tool path output was a ton of small arc segments. As a result, the machine was real jerky and I didn't get to fully see the advantages of a dynamic tool path. I decided to get the HSM option turned on and that made all the difference. One program ended up going from 45 min to just over 30. All that time savings from eliminating those exact stops. Highly recommend.
    Apr 2003
    3578
    This is do to no High speed look ahead and when running these paths there are allot of small moves and when you start turning the feed over 60ipm you have the jerking and this the machine can not keep up with the small moves that fast. I have delt with this for 20 years. Haas will give 200 hrs for trying this option out on the control being the High Speed look ahead as stated by Ken Foulks from the outlet.
    Cadcam
    Mar 2008
    638
    I'm not convinced it is the HSM, cadcam. We have HSM and we can get that symptom with the wrong CAM toolpaths. Maybe dingo0722 can update us?
    Apr 2003
    3578
    well I can agree with path typs as how are you handling the transitions between surface cuts. What kind of speeds are you talking about. as I have easily ran the HMC and the VMC haas's at over 400ipm for many company's with no issues doing roughing and finishing.
    So I would like to see if Dingo got his or her's situation taken care of.
    Cadcam
    Mar 2008
    638
    There are lots of settings in CAMWorks that affect this. zig-zag versus zig only for example. But that increases cycle time considerably. And, counter intuitive (if you ask me), setting it to line moves only, makes for smoother finish. More but unless you use the same CAM it's pretty useless.
    The size of the part and tighter curves affect it also. We make small parts with tight small radii. 17-4ss and titanium mostly
    Going over 80 ipm is a waste of time unless the part is bigger with larger sweeping curves.
    400ipm. I'd like to see that. Can you post a sample program for a 1/8" ball endmill cutting a simple 1" slightly curved top with .06 radii on edges? If this is possible on our VM-2 or VF-2ss, I need to know.
    Apr 2003
    3578
    extanker59, give me a sample of waht you want. I figure you are using SW so I can take that file. and I am figuring you want to be cutting alum with this path.
    I do understand your thoughts on the 17-4 or TI. I usually do not go over 120 or so in Ti matters on the shape and the cuts.
    Cadcam
    Mar 2008
    638
    I sent you an email with the SW part attachment to your website contact. Thanks for looking at it.
Page 1 of 2 12
  1. Machine has a stutter.
    By donl517 in forum Fadal
    Last Post: 02-27-2014, 04:49 PM
  2. BP axis stutter
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 04-28-2010, 08:59 PM
  3. threading stutter
    By theatrewizard in forum Haas Lathes
    Last Post: 05-26-2009, 01:08 PM
  4. Motor stutter help!
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 10-13-2007, 08:08 PM
