586,058 active members*
4,344 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > mitsubishi hobing with fanuc 0m controller help
    Nov 2009
    19
    hi friends.
    we have a mitsibushi gb15cnc hobing machine with fanuc 0m controller.
    and we have a problem on it.
    if you check the attached pictures, you understand that we couldn't see the option 4 and 5 at the menu screen.
    after a parameter loss, we reload the parameters but after that this condition occured.
    we found a page about reaching optional parameters(in attached pictures)
    but we could not understand what it says at step 6," insert option #"
    what is this "#" means?
    the last parameter finished at 9003 in the system but this page shows 10060-10066
    so do you have any suggestions regarding how can we enable this two option
    and how can we reach the parameters 10060-10066.
    thanks.
    Nov 2019
    4
    Red face Re: mitsubishi hobing with fanuc 0m controller help
    Hi: You have the same machine as we do. I'm researching to find a solution to your issue. Would you share your parameter files with us?
    Thank you in advance.
  1. Mitsubishi ladder for m50 controller AO
    By frith in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2021, 09:08 AM
  2. Warthog w/Mitsubishi controller
    By gregj1 in forum Uncategorised WoodWorking Machines
    Last Post: 12-10-2013, 07:23 PM
  3. Alarm Z70:illegal abs, Mitsubishi Meldas M64 controller
    By Vezku in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-15-2011, 08:40 PM
  4. controller for Mitsubishi MR-J2 drivers
    By cncor in forum Controller Cards
    Last Post: 10-11-2010, 12:08 PM
  5. Battery Failure on a Mitsubishi Controller
    By gearmachinist in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-14-2009, 11:08 PM
