586,069 active members*
3,663 visitors online*
Results 1 to 6 of 6
    May 2010
    Mach 3 with a PMDX 126 Board , 107 spindle board
    I Have a Hungyan Inverter and a water cooled spindle.
    Running Mach 3 with a PMDX 126 Board , 107 spindle board and a 134 mother board for 3 Gecko 203v drivers. Have all axis working.
    I am Able to Start and stop the spindle but not able to change the rpm.
    Had it working with a Gecko G540 but wanted to upgrade the system.
    Any one else useing this setup ,and what settings in MAch3 am i missing?
    Thanks for any help
    Apr 2010
    294
    I have the previous PMDX - the 125 - so I suspect I'm fairly similar. Mines a Mitsubishi inverter.
    In the ports and pins configuration in Mach3, SpindleSetup tab: I have "Use Spindle Motor Output" and "PWM control" ticked, but not "Step/Dir Motor". PWM base frequency is set at 30 and minimum PWM at 1%.
    I found I didn't get anywhere until I realised that the PWM frequency required by the PMDX has a minimum value. This might help.
    May 2010
    Thanks for the Info
    Thanks for the Tip,but it didnt make a change.
    Got the relars to work but when the spindle comes on , K2 relay shuts off.
    turn spindle off and it comes back on. not quite shure what is causeing it though(Will keep pluging away at it though)
    Apr 2010
    294
    I'm not using the relays on the main board to control the spindle at all, so if they're on or off doesn't matter to me. My inverter is powered up all the time, and the start stop signal is coming from pin 5 on the PMDX 107 board.
    Sep 2005
    1195
    Hello Jandalaser,
    Do you have wiring diagram if you can post it here for reference? I have previous version 126 and 107.
    May 2010
    Thansk To All who Replied
    Well I changed the 2 wires from the K1 relay to the 107 board, removed the 10 volt power supply from the VFD and capped it ,moved the Acm from VFD to the AGnd terminal & VI from VFD to AOut on 107
    Moved the Pump Wires to K1 relay and Everything works Perfect !!!!!
    I Have gone from 38 IPM with the G540 to 100 IPM with the 302vs
    Thanks Again for all the help
  1. PMDX 107 board wiring to Teco VFD
    By Jackal66 in forum CNC Machine Related Electronics
    Last Post: 10-08-2011, 05:33 PM
  2. New product announcement > PMDX-125 MultiMode Breakout Board
    By morestuff in forum News Announcements
    Last Post: 01-13-2010, 04:05 AM
  3. advice sofware with gecko 202 & pmdx board for mill
    By ajitsingh in forum Machines running Mach Software
    Last Post: 08-10-2006, 05:09 PM
