Hi All,
This is my first post on CNCZone! I hope it's not too silly.
I have a question regarding machining tolerances, and in particular, realistic flatness and parallel tolerances.
I am in the process of designing parts for a CNC router that I hope to have professionally machined. One of the parts (image attached) requires a plate to be machined flat on one side (the back side) and then have channels machined into the other side that will hold linear guides and a ballscrew support unit. The depth and coplanarity of these three channels needs to be pretty accurate, but aside from that the thickness of the rest of the part is negligible.
If I asked a machinist to machine these channels to be be parallel and coplanar with each other and with the back of the part to within +/-0.05mm (0.001"), would this be relatively easy to accomplish on a CNC mill? Or, would grinding need to be employed?
Any input would be greatly appreciated!
Toby
