i have an Optimum Bf 20l which i converted to cnc with the cnc conversion set.
Everything is working fine except the z- axis.
I can controll it with manual joging and it works great.
But if i try to run a g-code the machine goes to e.g. +3.000 and should then plunge to -2.000. Instead it only plunges to something between these number(and never consistent!). Also the feedrate is a lot slower. As i said this problem occurs just by running a gcode, with normal control with the arrow keys there are no problems.
I already tried to reduce / increase the feeds and also the acceleration.
I also tried a different kernel speed.
The power supply should also be ok (this problem occurs just when plunging down!)
Any suggestions why the z- axis is behaving like that?
Thank You!
