Hello,
I need independent NC Code Import Utility
Fanuc-compatible 3-Axis mill G code files can be converted into graphic toolpaths and subsequently add Bridges (jumper (tabs) like in ArtCam), and subsequently export back to NC file.
P.S. I need add Bridges in different NC files - one function only!
Who can help me, maybe there is free software for this?
...maybe one can make it?
P.P.S> When cutting out a part from a piece of wood, there is a moment when the bit will cut through the last piece of wood holding the part to the rest of the wood. At this point the forces may cause the part to simply be forced out instead of precisely cut out. If the part is complex it is possible that this may happen even earlier in the last cutting pass, causing the wood to be snapped and the part to be damaged.
The solution is holding tabs. These are small pieces of wood that are left in place to hold the part to the rest of the wood. After cutting has finished the tabs can be broken, perhaps with a Dremel, then sanded away. This creates control over the process of removing the part, and will avoid any damage.
