586,523 active members*
3,328 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tornado 200 Fanuc ot not responding spindle and turret
Results 1 to 11 of 11
    Feb 2008
    12
    Hi, i have a big problem. I bought lathe tornado 200 with no backup baterry. I upload all parameters, zeroes, but i'm not sure with params 900 - 940, i copied it from similar machine, which has a barfeeder.. When type in MDI T1 M6, CycleStart button still lighting, but response of machine is NOTHING. The same, when i try rotating turret by hand. When i type S200 M3, the spindle still stop and on spindle inverter LED's lighting "--".
    Sep 2007
    371
    If this is a lathe, for the tool change you need to write T0101; M06 is for mach. centers.
    GP.
    Feb 2007
    156
    Did you put the diagnostic or "pc" parameters back in? If not it won't run like it should (ask me how I know that!) They are numbers 300-549 on the diagnostic page.
    Parameters 900-940 are the ones that tell the control how many options and basic functions you get.
    The spindle won't start unless the chuck is clamped.
    Dave
    Schneider Machine
    A force of one
    Feb 2008
    12
    Dave
    And where i get this Diag params?
    Feb 2007
    156
    You have to find a lathe just like yours or get a hold of a dealer that sells or sold tornado lathes. The diag parameters control all the switches that run the lathe. If you can save to a pc that would tell you if they are there. Put the control in edit, push the diag/parameter button, might have to push it twice, it should say diagnostic in the upper right hand corner of the screen, then push output and it will send them to the pc. Look at the file, the number you will see are 10300-10549. If they come up with all zero's then they are missing.
    I just went through this on my Takisawa with a Fanuc 0T, I was able to get them from the Takisawa dealer, thay had them on file thank goodness.
    Good luck,
    Dave
    Schneider Machine
    A force of one
    Feb 2007
    156
    I would email this company, maybe they have them or can send you in the right direction.
    http://www.machinery.co.uk/directory...-Lathe-Co.aspx
    Dave
    Schneider Machine
    A force of one
    Mar 2007
    114
    I have a tornado 200 and if you supply an email address i will see if i can send you a full set of parameters when i get to the shop in the morning if thats any use to you
    regards
    Richard
    RRb Machining Services ltd
    Jan 2011
    can you pl help me tornado 200 parameters & dgn
    thanks in advance
    tushar
    Feb 2004
    52
    Don't know if this was resolved, I'm ex 600 Lathes if anyone needs help
    Les Robbins CNC Services - Index
    Apr 2011
    Did you get the Parameter & dgn. DO you have the operator manual.. I am stuck with a Torado 200 and no one is ready to take up maintainence due to unavailability of manuals.
    if you could pls hlp.
    Kamal
    Feb 2004
    52
    Kamal
    what is the machine serial number ?
    regards
    Les Robbins
    EditComm - CNC communication software - Les Robbins CNC Services
  1. Replies: 11
    Last Post: 11-01-2012, 10:10 AM
  2. Colchester Tornado Fanuc 21i-t
    By Stebedeff in forum Fanuc
    Last Post: 11-08-2010, 02:43 AM
  3. fanuc 21i double turret
    By nabil_elbadri in forum Fanuc
    Last Post: 01-12-2008, 06:08 AM
  4. Fanuc 18i - KIA SKT250MS - Turret ?
    By Joey in forum Fanuc
    Last Post: 02-27-2007, 05:23 PM
  5. HELP! need FANUC motor for my turret press
    By recycleroy in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2006, 08:19 PM
