586,512 active members*
3,671 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > need some help with fanuc-ot 900 parameters.
Results 1 to 15 of 15
    Jan 2009
    7
    Hello.
    I have some 900 parameters for the fanuc ot controler.
    My 900 parameters are vissable,and when i set my pwe to write anable i can write in my parameters.
    but when i want to write a specifit bit of a 900 parameter i can only writy the last 2 bits.
    For example.
    to change parameter 940 from 00000000 to 10000000.
    this wil work.
    but change from 00000000 to 00000001 it wont work.
    In both change i gat the 100 and 101 alarm,so turn af the machine and turn it on again.
    but even then it wont work. for the last option
    I hope someone can help me.
    Feb 2006
    59
    If I recall correctly some 900 parameters that open some options require the actual hardware to be connected. That may be why some of them won't work on your machine.
    Jan 2009
    7
    ok.
    it can be thru.
    But the first one i want to try is the parameter to set a clock in my display.
    And i don`t think that we need hardware for that??
    Or do i have it mistaken.
    Feb 2006
    59
    I think you also need to set a parameter, i do not remeber which one, i think is 0060.2, or 0014.2
    Check the manual if you have one,
    Good luck!
    Jan 2009
    7
    I have no manual.
    Are those parameters to aet the time.
    Or are thise parameters to write enable some 900 parameters.
    Oct 2010
    131
    Hi James007
    May be i can help you here, tell me what option u want to ON??
    It is not clear from above...
    What i understand from above is u want to ON, cycle time and parts count option..
    Tell me exactly what you want here....?
    Feb 2006
    59
    Those are to show time information in the display, im not sure if they will work, but it is worth a try....
    Jan 2009
    7
    Hi .
    There is one option i mis on my ot.
    I had it on a other fanuc mt.
    Its a option to copy.delete.copy etc caracters in a program.
    For example . When my cam program write a mil cycle it sets a feed in every g1 code.
    My option is to delete the feeds in that program en put one feed for al the g1.
    Becorse its dangers to set parameters.
    I first want to change one i have.
    So i want to change the time.
    Not the cycle or part count. But the realy time.
    I know it is possible on a ot, becurse i have seen it on a ot.
    When i know how to turn it on ir if i can search the parameter to enable the copy.delete etc option.
    If there us enywone that can help. Thx
    24223
    PM sent.
    Al.
    Albert E.
    24223
    Quote Originally Posted by james007 View Post
    Hi .
    Personally I have never seen that option, doesn't your CAM program have a Search - Delete - replace etc?
    You could remove all references to the Feed rate and leave just the first one?
    Al.
    Albert E.
    Jan 2009
    7
    Al.
    I dont know that.
    But i want to do something with parameters.
    The problem is the one i write.
    Can write some 900 parameters.
    But other i can write.
    When its posible to change it in the cam file i must look in the post proc.
    I think its more less work to change it on the machine.
    24223
    Usually this happens if they are non-existent parameters or they require a hardware add-on.
    Al.
    Albert E.
    Jan 2009
    7
    Al.
    Thx.
    Next week i wil try the menu parameter.
    When it works i let it know.
    If you have other par option there are always welcome.
    If you want my list please pm me.
    Greethings.
    Sep 2020
    7
    Re: need some help with fanuc-ot 900 parameters.
    hola me puedes dar una copia de tu manual de parametros 900 para un fanuc 0t por favor
    Jan 2009
    7
    Quote Originally Posted by vortech View Post
    Hi
    Please pm me you mail adres.
    I can help you with some document .
    I don’t know if it is you search but we will give it a try.
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. fanuc 11m parameters
    By sootblower in forum Fanuc
    Last Post: 08-11-2018, 08:30 AM
  3. Fanuc parameters
    By Mehboob ur Rehm in forum Fanuc
    Last Post: 02-28-2012, 09:54 AM
  4. Fanuc 3T Parameters
    By vsmvj in forum CNC Swiss Screw Machines
    Last Post: 10-20-2010, 08:22 PM
  5. Parameters Fanuc 6M
    By Olsson in forum Fanuc
    Last Post: 12-26-2009, 03:07 PM
