586,116 active members*
3,413 visitors online*
Results 1 to 11 of 11
    Sep 2009
    47
    Talking 3D DLP Printer Project
    I have been thinking about this project and gathering parts for some time and I think I am ready to start building. Up until now the biggest road block was software but Printrun has a projector mode that works with skeinforge's craft output.
    DLP Engine:
    I plan on using a dlp engine from a dlp tv that was broken on craigs list. This should give me a larger print area than with a projector.
    Electonics:
    I am using an Arduino nano with teacup firmware loaded and a hobbycnc steper driver. The stepper driver has a blown X and Y but the Z and A still works which is all I need.
    Materials:
    1/2-10 acme lead screw
    2x 18" 20mm linear rail
    I am using corian since i have a ton laying around but plywood or MDF should work.
    The opening in the base is 12"x9" and the frame is 18" tall so I should get 14"-15" of z.
    Attached Thumbnails Attached Thumbnails DSE_3821.jpg   DSE_3822.jpg   DSE_3823.jpg   DSE_3824.jpg
    I am here for the pictures.
    Sep 2009
    47
    frame build
    I had some 20mm linear rails left from an early router attempt. I tapped the ends for mounting. For the lead screw, I turned down both ends to 8mm and tapped one end. The other end I used a cir-clip and I used 2 608 bearings for mounting.
    Attached Thumbnails Attached Thumbnails DSE_3827.jpg   DSE_3828.jpg   DSE_3829.jpg   DSE_3830.jpg
    Jun 2011
    Interesting, what sort of epoxy are you intending to use?
    Sep 2009
    47
    Vat build
    I plan on trying the solarez lovoc polyester resin. At 44$ a gallon its decently priced.
    I did lot of testing on using a non stick surface on the bottom of the vat. I tested touch screen protectors and mylar which did not work and . I settled with adheasive backed FEP film from mcmastar carr. McMaster-Carr. Applying the adhesive back sheet without any wrinkles is extremely hard since the adhesive is supper sticky and you only get one shot.
    I am also investigating into polyethylene plastic. Test curing on a freezer storage bag worked beautifully however I have not been able to find a clear adhesive backed source.
    The bottom is made from 1/4" inch plate glass and the sides are 1/4" plexiglass. I used glass etch around the edges of the plate to help the plexiglass stick better. Its all glued together with gorilla glue and silicone.
    Attached Thumbnails Attached Thumbnails DSE_3831.jpg   DSE_3832.jpg   DSE_3833.jpg   DSE_3834.jpg
    Sep 2009
    47
    New progress, built the stage. The part extending into the vat will be 2 pieces of 3/4 corian. The rest is aluminum plate and a delrin lead screw nut
    Attached Thumbnails Attached Thumbnails DSE_3837.jpg   DSE_3838.jpg   DSE_3839.jpg   DSE_3840.jpg
    Jun 2011
    Have you thought about how your going to break the layers adhesion to the tank bottom?
    I've seen a couple of mechanisms including tilting the build platform and more recently sliding the tank.
    Sep 2009
    47
    Quote Originally Posted by rpovey View Post
    I have seen some of those mechanisms as well, one that pushes down on the vat to pop the layer off and another that slides it back and forth. I am hopping that the FEP film will be non-stick enough that it will not be need. I did some adhesion tests before I started building and I think it worked out well.
    I do have concerns about the cure depth. I might have to look into a UV blocker to mix into the resin.
    May 2005
    2502
    Been very interested in seeing a build log for this style of machine. Thanks for posting.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jun 2011
    My concern would be that even with a nonstick base, you'll still have two mated flat surfaces, so I think you'll need some mechanism to "break" seal.
    Either way I'm interested to see how it works out.
    Aug 2008
    409
    Im building one of these next, im currently building a large format reprap style 3D printer.
    A couple of things I have learned from the various groups and forums about the 3D DLP method is that the vacuum force that exists when you print a part on the VAT floor is very high, Your FEP film will not help release the vacuum, you need something to break the seal, I think the Sliding method along with some PDMS silicone on the VAT bottom is the best so far.
    Also, from my research, I think that the Solarez stuff is not really suitable for this type of printing, too slow to cure. You'll want to go with one of the DLP 3d Printing resins that are now available from places like http://www.spotamaterials.com/ or Bucktown Polymers - The Future of Polymers
    They are made for this specific application and should work well with your setup.
    Also, ive heard that the Castin Craft Resin dyes work well for coloring and for reducing the cure depth.
    I have a few questions, you mentioned you were using the DLP from a TV, have you figured out the optics and light source?
    Good luck with your build, check out the yahoo group on 3D printing for a ton of info on this method. I look forward to watching your progress!
    Sep 2009
    47
    I have been busy with a different project so I have not gotten much done lately. Here are a few pics of my first attempt to print. Cure times and UV permeation is definitely something I have to dig into
  1. I can haz 3D printer too?
    By jeremy0203 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 03-18-2012, 05:29 PM
  2. 3D Printer or X3D Printer
    By mikemill in forum Syil Products
    Last Post: 02-15-2012, 03:41 PM
  3. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  4. Mastercam X3 and Printer Do Not Get Along
    By zephyrmachine in forum Mastercam
    Last Post: 05-13-2010, 12:10 PM
  5. Printer for PCB ?
    By WayneHill in forum CNC Machine Related Electronics
    Last Post: 10-05-2005, 06:42 AM
