Originally Posted by
9wleadfoot
Is there a setting or something to do or change. Tried engraving some text on a round part in the rotary it was programed with gibbs and rendered correctly but the actual engraving was mirrored on the part when milled. The 4th axis mirror setting is in the off position. I would think if it rendered right it should mill right?
Sounds like the rotary should be going the opposite direction. Like A- instead of A+ or visa-verse. Just change that.
