586,094 active members*
3,896 visitors online*
    May 2012
    Biesse NC500 using .DXF
    hey guys,
    I just recently changed jobs. I was using a Biesse Rover 22 and now im using a Rover 24 in my new job. These new guys dont use autocad (or any cad software), they do everything inside NC500...including complex shapes which take them hours to draw up. So i installed autocad 2000i for them and tried to import a DXF but it tossed up the error 'unknown layer 0' or something similar even tho i have specified the layer in the DXF setup of NC500.
    anyone know a DXF setup that works.
    panel name -
    router name -
    side 1, 2, 3, 4, 5 drill names etc etc.
    thanks for any help.
    Jul 2008
    7
    nc500 import
    panel name in setup ,panel example layer name -panel32p9
    router name in setup , router example layer name -router8mm12pr5
    8mm being the name of the tool
    12p0 is the depth
    r is righthand correction
    5 is circular z infeed
    Jul 2014
    Re: Biesse NC500 using .DXF
    Hello, i have a biesse rover 20 and i am using autocad dxf files for import to nc500. For example my layer is 13MM1P50R0, means 13MM tool, 1.5 depth, right direction and 0 in-out. I have two questions:
    1. what is layer name if i can change Z axis (for example i want to line with start depth 1 and 1.5 depth on end of the line), how can this exaple add to layer name?
    2. Is it posible to set tool sequence, means if i have for example 3 rectangles in autocad and i want to start rout with second, or change to sequence which i want?
    thank you
    Alex
    May 2015
    7
    i have rover 20 with nc500.
    where do i setup layers on nc500?
    i need it to communicate with DXF files i sent to it from MasterCam.
    need help on what to name leyers in Master Cam so NC500 can read it.
  1. biesse rover 20 nc500
    By mdem in forum DNC Problems and Solutions
    Last Post: 09-14-2021, 08:15 PM
  2. Biesse Rover NC500
    By michasio in forum Uncategorised WoodWorking Machines
    Last Post: 04-03-2014, 12:15 PM
  3. biesse NC500 jump commands
    By kuffster in forum CNC Machining Centers
    Last Post: 09-22-2012, 11:05 PM
  4. biesse nc500/nc1000 users' guide needed
    By carlton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-09-2011, 08:04 PM
  5. nc500 Rtu
    By kurikaru in forum DNC Problems and Solutions
    Last Post: 04-22-2003, 02:13 AM
