586,350 active members*
2,890 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Thru-the-tool coolant - tool life
    Feb 2011
    Hey, just a general question on coolant pressure (I guess mainly on thru-the-spindle/tool coolant) ...
    ...how much can I expect tool life to be improved, with everything else being equal, when going from 100 psi to 300 psi? Or how about 300 psi to 1000 psi?
    I have to write a justification to get 1000 psi coolant on a new machine and was looking for some data...
    Thanks for any info!
    Feb 2011
    ...and the material being cut is usually ductile iron, around 250 BHN...
    Thanks!
    May 2004
    4519
    I think you will find tool life is exponential to coolant pressure (and volume) and not linear.
    Feb 2011
    say what?
    May 2004
    4519
    For example, for the first 25% increase in coolant pressure and volume, you might see an increase in tool life of 50%. For the second 25% increase in coolant pressure and volume you might see and additional increase in tool life of another 25% from base line. For the next 25% increase in coolant pressure and volume, you might only get an additional 10% increase in tool life. Then for the final 25% increase in coolant pressure and volume you might only gain another 10% on tool life.
  1. Tool Life
    By dirtbiker1824 in forum CNC Tooling
    Last Post: 04-26-2010, 04:25 PM
  2. Renishaw tool offset / break probe and tool life management
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2010, 04:14 AM
  3. Tool Life
    By gmilosevic in forum MetalWork Discussion
    Last Post: 01-04-2010, 04:08 PM
  4. CBN tool life?
    By Pontiff51 in forum Material Machining Solutions
    Last Post: 02-27-2009, 01:15 PM
  5. Tool life
    By Muzzy in forum CNC Tooling
    Last Post: 04-11-2007, 10:47 PM
