586,033 active members*
3,518 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > WinCnc > Y Axis Stalling - followed by screaming motor
    May 2012
    hello all
    Ok here is the deal:
    3d router running a recent ver of wincnc on xp desktop
    New gecko G201 step motor drive, newer oriental motor PK299-F4.5A, couplings are all good
    Y axis occasionally stalls (or binds?) and results in lost steps
    Problem would manifest itself occasionally before replacing hardware, with the new equipment it seems even more frequent.
    This problem is intermittent during cuts, but can easily be induced by fast transits. does not appear to be a mechanical issue when turning by hand with machine off the action is smooth.
    I swapped the inputs on X and Y drives and the problem does not seem to repeat itself on either axis
    Thanks in advance for help
    the following is the wincnc.ini file which I assume may need some tweaking:
    [Timer Card Settings]
    timertype=7200
    steppulse=p5d5
    g09=s12
    maxstepv=50000
    [Axis Settings]
    axischar=XYZ
    [Table Size for Viewer]
    table=x0 y0 w73 h140 b2
    [Velocity Groups]
    vgroup=fxy
    vgroup=xy
    vgroup=z
    [X Axis]
    axisspec=p0 s0 d0 r3065 a650 f500 o1 e1 k1
    axisvel=r400 f125 s20 m100 h500 c5
    axislo=p3 b0
    [Y Axis]
    axisspec=p0 s1 d1 r3425 a650 f500 o1 e1 k2
    axislo=p3 b2
    [Z Axis]
    axisspec=p0 s2 d2 r9985.69 a300 f200 o1 e1 k3
    axisvel=r80 f100 s10 m25 h100 c5
    axislo=p3b4
    axishi=p3b5
    [Arc Settings]
    arc_err=.01
    arctype=t1
    autoarcfeed=f40
    [Soft Limits]
    lolim=x0 y0
    hilim=x73 y140 z6
    lobound=z-6
    softlim=1
    [Aux]
    auxin=c1p2b6o1d20
    enab=c1m"Emergency Stop"
    [auxout=c1p7b7o1s1e1
    [Abort Cushions]
    lim_cnt=10
    esc_step=1000
    lim_step=250
    lim_mode=1
    [G28 Settings]
    g28move=z-.125 r.125 f50 m1
    g28move=x.35 y.25 r.5 f100 m1
    [Keypad Settings]
    Keypad=c1b9600p2
    Keypaddir=c:\wincnc\jobs
    [Data Directory and Search Wildcard]
    filetype=*.TAP
    Sep 2011
    102
    Re: Y Axis Stalling - followed by screaming motor
    I know this is an old post but I recently had an identical problem in both the y and x direction. It turned out that I had a bad motherboard. After changing the motherboard to a Wincnc recommended motherboard the problem went away.
  1. X2, Stalling motor
    By nateman_doo in forum Benchtop Machines
    Last Post: 01-04-2011, 11:10 PM
  2. HF motor stalling out
    By surrealism in forum Mini Lathe
    Last Post: 07-01-2010, 06:08 AM
  3. Problems with motor stalling due to motor/lead screw alignment
    By Bimmerkc1 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 01:12 AM
  4. Taig Z axis stepper screaming!
    By Andy Fritz in forum Taig Mills / Lathes
    Last Post: 07-01-2006, 12:50 AM
  5. motor stalling
    By planescott in forum Mechanical Calculations/Engineering Design
    Last Post: 05-06-2006, 03:50 AM
