Hello All.
I'm working on a custom design large cnc router and looking for your comments o n my choices.
Some basics
2800mm x 1450mm
ethernet smoothstepper
SBR20 rails and blocks (Chai's) on all axes.
X axis:
2x 2800mm RM2505 ballscrew
2x Nema 23 387oz Stepper, G251s, slaved in mach3
Rotating nut design
48v PSU for two steppers
Y axis:
1x 1450mm RM2005 ballscrew
1x nema23 570oz stepper. G201X
48v PSU shared with Z
Z axis
1x 300mm RM1605 ballscrew
1x Nema 23 387oz stepper. G251.
2.2kW water cooled china-spindle and vfd.
The hard part will be the rotating nut design I suspect.
I've attached some renders of my design so far..
The renders are missing a bit of detail (bolts and nuts, aluminium angles etc) so it might not be clear how it bolts together, but you should get a rough idea.
The rotating nut design is basically a timing pulley bolted to the ballnut, sandwiched between two aluminium plates with three-piece thrust bearings between the plate and the nut. -see photos for more info.
Gantry is made of two 100x50x6mm C channels bolted one ontop of the other, with the rails bolted to the flat face.
I can post a solidworks e-drawings file if anyone is interested in looking at it in more detail.
Comments please... I already have all the parts listed above, so there is no turning back now!
