586,032 active members*
2,847 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Electro-craft E675 Servo Motor
    1695
    I was at the surplus shop and picked up a dead servo motor for $30. It's missing the carbon brushes, but I will order some from Ebay.
    I believe it's a wheelchair motor, but it is a true servo with a skewed rotor. There's no cogging and I can make it turn smoothly with 1v.
    The only problem is that I cannot find any information on Electro-Craft's web site. I would appreciate it if someone can provide me with specs on it.
    24221
    Cont stall torque 11.5 lb-in
    max terminal voltage 90
    rpm 5300
    Kt Torque cont 1.16 lb-in/amp
    Ke Voltage constant 13.7 v/krpm
    Al.
    Albert E.
    1695
    Thanks Al. That's quite a substantial motor. Hopefully it hasn't been demagnetized. I'll find out when the carbon brushes get here.
    Jan 2020
    Re: Electro-craft E675 Servo Motor
    Hi Al.
    I have this motor as well and could use additional data on it. Any chance you have and can share the spec sheet?
    Also could you please share your thoughts on implementing torque control for the motor.
  1. Help identifying an Electro Craft Servo Motor with a Renco Encoder
    By kevlar129bp in forum Servo Motors / Drives
    Last Post: 06-24-2013, 08:09 PM
  2. Electro Craft Servo motor
    By sermys in forum Servo Motors / Drives
    Last Post: 04-15-2009, 06:57 AM
  3. Electro-craft servo Please help
    By j186281 in forum Servo Motors / Drives
    Last Post: 06-15-2008, 04:38 PM
  4. Electro-craft servo's
    By punisher454 in forum Servo Motors / Drives
    Last Post: 07-30-2007, 07:13 AM
  5. Electro craft servo's query.
    By Georgie in forum Benchtop Machines
    Last Post: 01-09-2006, 01:37 AM
