Hello
Our co2 laser is overheating and we are in need of a chiller.
Can anyone help?
Many thanks
William
Hello
Can anyone help?
Many thanks
William
Do you need a refrigerated unit or will an air cooled unit to keep the water at ambient temp do?
If air cooled will do the a car radiator and a fan can be used.
:wee: You need a CW5000.
Please find if you can buy from ebay. This water chiller is very common in Chinese laser field.
Melody
[email protected]
Try the car radiator. Thats pretty cheap to find out, then if you need to go to a ref. type you can later. All ours are chilled, however our smallest one is still 400 watt.
Your laser will last longer and perform better with a refridgerated chiller. If you are running a cheap chinese tube, life may not be a big deal as the refridgerated chiller is more expensive than an armful of laser tubes. With an air cooled radiator, the temperature of the laser will gradually increase over an hour or two as the cooling system reaches steady state. The temperature of the tube effects power output so if you have a long job you could see variation over the job as the laser heats up.
If you specify what your laser is and how it is used it would be easier to suggest a cost effective solution.
Matt
Hiya Will,
Give me a call and I should be able to help (I don't sell chillers but may be able to help with your overheating problem)
07429 149371 (I'm in the UK so not far away)
best wishes
Dave
alternatively text me and I'll call (It's a business line so it's free for me)
we are the CW5000 chiller manufacturer,if you have any problem,i can help you ,my Email:[email protected]
what is your laser power? i can help you,we are the chiller manufacturer, my Email:[email protected]
Hi William
Could you please tell us how many watts with your laser tube?
Your answer will can help you to order a suitable chiller to cooling the laser tube.
So now if you are using the water pump to cooling the laser tube?
Tell us more details and someone(or the chiller manufacturer) can provide a good solution to you
Sincerely
Tom
Thunderlaser- leading provider of laser cutter and laser engraver from China
