586,556 active members*
3,326 visitors online*
Page 12 of 50 2101112131422
Results 221 to 240 of 995
  1. #221
    Jun 2010
    1414
    I just threw a bag of the countertop mix in the car, along with 2 of the 45x90 pillars. Going to fill them at work tomorrow. Doing 2 at a time.
    Side note. besides my X2 motor taking a dump, this was im sure a likely contributor:
    DARN GIBS! One of the first things I plan to do when I finish my linear rail build, is to machine the gibs clear off my X2 build and convert that to linear rails.
  2. #222
    Jun 2010
    1414
    Packed 2 of the upright columns.
    The countertop mix is nice and soupy. Probably too soupy. I have been beating the column and drops of water occasionally spout out. Not really that concerned with the mix itself, just looking for its dampening qualities here.
  3. #223
    Jun 2010
    1414
    The weight of the beams went from 8lbs to about 15 lbs.
  4. #224
    Jun 2010
    1414
    I would be lying if I said i wasn't excited:
  5. #225
    Jun 2011
    279
    Ah, the hurry-ups has finally started to bother you........
    Sweet looking VFD.
    Chris
  6. #226
    Oct 2003
    927
    Is that the GS22PO model? ..and can you mention where you ended up getting that threesome(VFD, resistor, reactor) from?
    Shoptask rebuild:
    http://www.cnczone.com/forums/showthread.php?t=2139
    Home built gantry router:
    http://www.cnczone.com/forums/showthread.php?t=5049
  7. #227
    Jun 2010
    1414
    Quote Originally Posted by Bloy2004 View Post
    GS3-22P0
    All at automationdirect.com
    GS3-22P0
    LR-22P0
    GS-22P0-BR
  8. #228
    Jun 2010
    1414
    Quote Originally Posted by cjsamples View Post
    Sweet looking VFD.
    Chris
    I am terrified of that. I am MOST terrified of the concrete pour. Everything is prone to change... but once that concrete gets poured... it will be the devil to get off!
  9. #229
    Jun 2010
    1414
    Just scored the additional 80/20, and the concrete is drying in the 4 uprights now.
    Extra rails will arrive tomorrow, and the geko drivers Friday.
  10. #230
    Jun 2011
    279
    Z axis
    So, I have been reading along with everyone else and wanted to find out more about your Z. Have you planned that out yet? Is there going to be a column it will be mounted on or planning something else? I am trying to remember if you covered that yet. I remember seeing the Z axis plates but not the column or how it was going to be mounted.
    Inquiring minds want to know.
    Chris
  11. #231
    Jun 2010
    1414
    Those 12" x 24X plates will get bolted to the Aluminum extrude frame. Gantry style, but it doesn't move. Once I finish the frame it will become more apparent. Still filling the extrudes with concrete. All 4 pillars have been filled. Those are lunch break items at work.
    Right now I just finished wiring up the dedicated computer, and the 50V power supply. All the electronics will be in a NZXT midtower computer case. The board is an X58 micro ATX, intel i7 920 (quad core 2.6GHz), and an Nvidia 8600 GTS.
    A bit of a waste, considering what I have running my X2, but I have had the system in the closet for about a year. Oh yea... and a Solid State hard drive
  12. #232
    Jun 2004
    6618
    That should work very well.
    I do have a small 60 GB SSD in my desktop. It is only used for Cache though.
    I have been eyeballing them for reduced cost lately. They are coming down some now and increasing in size.
    I'll hold off just a little longer.
    Lee
  13. #233
    Jan 2006
    2985
    I put an SSD in my laptop and it is SWEET!
    Matt
  14. #234
    Jun 2010
    1414
    Yea, the SSD is the single biggest upgrade you can do to a computer these days. Clock for clock getting a faster processor you might not notice, but an SSD every program loads so much faster. I figure that might help Mach. The drive isn't big enough for my daily usage, so I just figured it would be put to good use here.
  15. #235
    Jun 2010
    1414
    This VFD wiring is staring at me in the face and not clicking yet.
  16. #236
    Jun 2011
    279
    huh?
    where does it have you confused?
    Chris
  17. #237
    Jun 2010
    1414
    There is so much going on with the BOB. Past the com step dir per access, the rest takes actual thought. The wiring diagram on the BOB leaves much to be desired.
  18. #238
    Jun 2010
    1414
    The computer w/all the additional hardware in it:
    And the internals of the VFD:
  19. #239
    Jan 2006
    2985
    You have a link to the BOB diagram?
    Does it have a built in analog output for spindle control?
    Matt
  20. #240
    Jun 2011
    279
    C11 board
    Think he said he was running a C11. I run a C11 and it says it will do spindle control.
    I will be finding out soon as my eBay offer for spindle and vfd was accepted!
    Chris
  1. 14x14 Linear Rail Industrial Hobbies Build (Charter Oak Automation)
    By nateman_doo in forum Vertical Mill, Lathe Project Log
    Last Post: 03-06-2023, 08:14 PM
  2. Open Rail DIY Linear V Rail System
    By kram242 in forum News Announcements
    Last Post: 06-11-2012, 03:33 PM
  3. Linear Bearing vs Linear Rail
    By microdot in forum Mechanical Calculations/Engineering Design
    Last Post: 10-27-2009, 04:54 PM
  4. PBC Linear Offers New Profile Rail Linear Guides
    By Pacific Bearing in forum News Announcements
    Last Post: 04-30-2009, 09:53 PM
  5. 6'x10' cnc build, what linear rail setup to use
    By davy182 in forum Linear and Rotary Motion
    Last Post: 04-06-2009, 11:51 PM
