586,075 active members*
3,984 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Questions about an old control/ its psu/ a new psu/ old servos
Results 1 to 11 of 11
    May 2010
    48
    got an old saeilo robotool mill with dead control
    on the main board that receives power from the transformer
    it reads "160 volts"
    the motors are labeled "62volts / 3.75 amps"
    220v is fed into main step down transformer to 120v
    then to rectifier then to main power board for the amps
    1. why are 160 volts being fed to the servo amps if the motors 62 volts?
    2. if i buy a new psu for the servos should it just be 62 volts and add up the amps?
    sorry if these are dumb questions
    thank you for your time
    Dec 2003
    24221
    What make/model are the drives used in the old control?
    It is normal to size at least 112% P.S. voltage above motor terminal voltage.
    But that 120vac secondary seems a bit high?
    Did you measure the P.S. DC voltage?
    Al.
    Albert E.
    May 2010
    48
    Al.
    hello sir
    i am thankful of and honored by your post
    my electrician friend was here yesterday and we intended on measuring the output but ultimately did not
    i am planning on going with the dugong 80v/20a drives
    and decided to just go ahead and buy a new supply
    if the dugong is 80v do i want to supply it with 62v x 112% ?
    or just get a supply for 62v?
    here is the one i was looking at:
    Antek - PS-8N63
    i want to make sure because i am on the verge of ordering everything
    as the project is just waiting for components
    the old drives just say robotool
    and the power distribution board says applied microbotics
    i will take pics later today more than likely and post them
    right now i am tearing old j head apart to deliver to the guy that bought it
    to make room for the new guy
    Dec 2003
    24221
    With a 62VDC supply you will get just something under max. rpm.
    Al.
    Albert E.
    May 2010
    48
    Al.
    man that was a fast reply
    are you saying thats good to go or no?
    sorry the heat is getting to me and want to be absolutely sure
    Dec 2003
    24221
    Well if you think you can live with slightly less rpm than the motors are rated for then it will be OK.
    Al.
    Albert E.
    May 2010
    48
    Al.
    i see what you mean
    can you recommend supply ratings for me that will do the trick?
    thanks again for your help sir
    Dec 2003
    24221
    I would tend to look at what the setup had previously to see if anything can be re-used, do you have the schematics or machine drawings?
    Al.
    Albert E.
    May 2010
    48
    Al.
    that was my original intention - to reuse the power supply section
    and maybe some of the relay stuff -
    but to ditch the old drives
    dont have any schematics or diagrams
    but i will take and post pics later to give you an idea of what was going on in there
    my plan is:
    EtherSmoothStepper and basic bob for it
    3 dugong 80/20 drives
    power supply at ?v?a
    :drowning:
    Dec 2003
    24221
    With those motors (3?) you would need ~ 350 to 500va power supply, 65vdc to 80vdc.
    Al.
    Albert E.
    May 2010
    48
    Al.
    so youre saying ill get a little more bazing out of the motors
    as long as i stay within those confines but above 62V
    i really appreciate your help sir
  1. Any motor experts? Have some questions re: steppers/servos
    By SRT Mike in forum Linear and Rotary Motion
    Last Post: 10-19-2011, 09:09 PM
  2. Questions About Changing From Steppers To Servos
    By Brenck in forum Linear and Rotary Motion
    Last Post: 10-01-2009, 07:35 AM
  3. Questions regarding Servos motor and drives
    By Syphonics in forum Servo Motors / Drives
    Last Post: 07-26-2009, 07:25 PM
  4. Tech Questions, TC-2, Fanuc 2T, Program, Way Luber, and Servos
    By RonRoy2004 in forum DNC Problems and Solutions
    Last Post: 01-10-2006, 03:01 AM
  5. Servos or Steppers..... and other gecko related questions
    By UKRobotics in forum Gecko Drives
    Last Post: 04-19-2004, 08:14 PM
