got an old saeilo robotool mill with dead control
on the main board that receives power from the transformer
it reads "160 volts"
the motors are labeled "62volts / 3.75 amps"
220v is fed into main step down transformer to 120v
then to rectifier then to main power board for the amps
1. why are 160 volts being fed to the servo amps if the motors 62 volts?
2. if i buy a new psu for the servos should it just be 62 volts and add up the amps?
sorry if these are dumb questions
thank you for your time
