586,655 active members*
2,577 visitors online*
    Sep 2011
    296
    Tips for laser power supply & tube upgrading
    To friends here who want to upgrade laser power supply and tubes after some time using:
    Tip 1: As for the power, not the larger the better. Power larger than 100W can not engrave well.
    If your work is only cutting, then it is helpful if you upgrade so that you can cut thicker material and have faster speed.
    If your work is only engraving, the best power will still be around 60W.
    The best point for both work at the same time will be 60W-80W/Reci W2.
    Tip 2: The larger power supply can give power to smaller tube but not vice versa.
    Sep 2011
    296
    Some parameter for Chinese tubes :
    Reci:
    W2 90W, peak power 100W length: 1200mm diameter: 80mm
    W4 120W, peak power 135W length: 1400mm diameter: 80mm
    W6 150W, peak power 170W length: 1650mm diameter: 80mm
    W8 170W, peak power 195W length: 1850mm diameter: 90mm
    Other brand tubes:
    80W length: 1600mm diameter: 80mm
    60W length: 1200mm diameter: 55mm
    40W length: 1000mm diameter: 50mm
    30W length: 700mm diameter: 50mm
    25W length: 600mm diameter: 50mm
    Melody
    [email protected]
  1. We supply you CO2 laser machine also laser tube
    By masterandroger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2010, 04:41 AM
  2. is there any way of testing the power supply without a working tube?
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-24-2010, 12:51 PM
  3. Upgrading to G540, power supply questions
    By awetmore in forum Taig Mills / Lathes
    Last Post: 05-28-2010, 07:53 PM
  4. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
  5. Laser Power supply
    By technazz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-20-2007, 02:33 PM
