586,785 active members*
3,243 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Reduced Shank Milling Tools
Results 1 to 10 of 10
    Apr 2007
    21
    Hey everyone,
    I have searched everywhere and I can't seem to find any company that will make a reduced shank carbide endmill.
    I can find some reduced shanks that are about 0.03" smaller then the cutting diameter but I'm looking for something like 3/4" cutting diameter and a 1/2" shank. Or 1" cutting diameter with a 3/4" shank.
    Does anyone know where to find this kind of bit? The longer the tool is the better...right now I'm working with MDF board and a 6" OAL 1/2" carbide 2flute upspiral endmill (Onsrud). It works great but the mold I'm milling has really steep walls and the router is very close to hitting the mold.
    Any help would be greatly appreciated. I don't understand why no one would make these as I'm sure everyone would find this handy from time to time.
    May 2004
    4519
    This is not standard for carbide tools from any vendor I am aware of. You will have to buy the standard tools then send them out to be custom ground.
    Sounds like all you need is a longer end mill.
    Apr 2007
    21
    Yeah I was thinking about going with an 8" OAL bit...the distance it's sitting out of the collet is 4.5" right now with the 6" OAL.
    I remember seeing this milling tool once that had replaceable carbide inserts that you screw on. It's more like a facing tool. This would cut down the cost of the expensive over-length endmills and also has a bigger cutting diameter than the shaft. The huge difference in cutting diameter to shaft though is a bit scary.
    Do you know what those tools are called?
    May 2004
    4519
    There are inserted end mills and face mills available. Getting the right shank size with the extended reach you are asking for might be difficult. I recommend making friends with your tool salesman and let them do most of the leg work for you.
    Apr 2007
    21
    Yeah that was my next step. The problem is they handle almost everything we buy...from gloves, to bits, to rubber corn header flaps. I'll try to find an alternative and let ya know how it goes.
    Thanks for you input it was helpful
    Jan 2004
    56
    Smile Off the Shelf - Reduced Shank cutters - Harvey Tool
    I have no affiliation, (other than being a customer), but check out
    www.harveytool.com
    Good Luck!
    Apr 2007
    21
    Thanks dansutula
    It turns out I had a catalog from Harvey Tool. I looked through the catalog today (which I found among my other many catalogs) and couldn't find exactly what I was looking for. So I went to their site and you can special order pretty much any kind of tool you want. All you have to do is give the dimensions you require and they'll give you a quote before you buy.
    This is something I will definitely look into. It seems they spcialize in specialty tools. For anyone looking for an odd tool, I also recommend checking out Harvey Tool
    I'm a big believer in Onsrud for quality and strength. When I inquired about a special tool though, they weren't up to it.
    May 2005
    2502
    Acrynom, with that much stickout, use the largest diameter tool you can and keep a close eye on tool deflection. A 1" diameter cutter sticking 6 1/2" out of the tool holder can cut surprisingly little depth of cut (the part of the flutes actually cutting) before deflecting more than 0.001" which will really reduce your tool life.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Apr 2007
    21
    Yeah even with a 1/2" Diameter 6" OAL sticking out 4.5" really doesn't have a good cut if the depth of cut is over 0.3" at F120 in MDF. I can imagine adding another 2" wouldn't help. It's not so much that I have to mill the mold very fast since I usually leave it going over night and come back to it in the morning...it's that I can't reach certain areas.
    Another option I've used in the past since I'm using 5 Axis machines (we work primarily with thermoformed parts...very rarely only using 3 axes) is angled roughing and finishing. I like to stay away from that as much as possible, although it's not always possible.
    Re: Reduced Shank Milling Tools
    AcryNom...check out www.cgstool.com...while that that is a major reduction in the shank, we tool make specials and turn them around much quicker than the competition. Presently we do a fair amount of business north of the border.
  1. Extra Long Reduced Shank Drill
    By MNGalaxy in forum Want To Buy...Need help!
    Last Post: 05-15-2013, 11:40 PM
  2. reduced end mill with 1/4 Shank
    By adamski07 in forum CNC Tooling
    Last Post: 04-07-2013, 04:32 AM
  3. Easy tool height for straight shank tools
    By gateman in forum MetalWork Discussion
    Last Post: 04-03-2012, 10:32 PM
  4. What is everyone using to hold 1/8" shank tools?
    By Jaynboom in forum Tormach Personal CNC Mill
    Last Post: 01-25-2012, 12:00 AM
  5. Replies: 2
    Last Post: 10-07-2011, 10:56 PM
