051211-1712 EST USA
Poll of -- What RS232 Baud Rate do you use?
I have selected multiple choice so you should be able check each baud rate that you use.
This poll is essentially the same as the one under HAAS machines. The intent here is that this poll should apply to non-HAAS machines.
With a broader machine community I expect some difference in the shape of the distribution curve.
Comments on why you use a given baud rate, your cable length, and communication parameters would be useful. An example of why might be --- the machine vendor said to use ---- .
