586,121 active members*
3,685 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Light Machines 0400 cnc lathe help
    Jan 2010
    I acquired a light machine 0400 cnc lathe with control box I already have mach3 on an taig cnc mill (gecko) was wondering if anyopne can point me in the right direction on how to proceed converting this machine to use mach3 and does anyone have any control boxes ready to go that will convert this machine to mach 3? Machine is in very good condition I am also looking at cost trying to keep it low as possible and still have a dependable lathe. Thanks in advance
    Andy
    Aug 2009
    986
    If your lathe uses the same controller card as the Spectralight mill, then this may work for you. This fellow built a cable to drive the Spectralight from the parallel port, eliminating the need for the controller card and OEM software.
    Home [MeshCMS]
  1. Picked up Light Machines mill and lathe
    By crackerkorean in forum Benchtop Machines
    Last Post: 02-02-2009, 04:24 AM
  2. Retrofitting an Older Light Machines CNC Lathe
    By brainstatic in forum Uncategorised MetalWorking Machines
    Last Post: 02-02-2009, 02:35 AM
  3. Intelitek 0400 Lathe and Tool Changer
    By Too_Many_Tools in forum Mini Lathe
    Last Post: 08-24-2007, 08:04 PM
