586,052 active members*
3,906 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Easily identify a previous T/Cplane
Results 1 to 14 of 14
    Sep 2010
    135
    Im working on a multiaxis project with over 200 C/Tplane. Sometimes I find myself having to go back to an existing T/Cplane for a new operation or reoperation.
    My question is, is there an easy way of going back to an existing Gview and T/Cplane without having to identify them? Ie: like click on a face or key-stroke?
    Thank you
    Sep 2011
    Don't you just lable them as you create them?
    Sep 2010
    135
    yes it's what I'm doing...
    I'm just wondering if there is a easy way
    Sep 2011
    Quote Originally Posted by PRINT_FX View Post
    Actually, I think if you go to G-view, you can just click on a face, and it will go to that view if there is already one created.
    Apr 2003
    3578
    if you are going back to an existing operation MC will toggle automatically back to that T/C planes to make changes.to set planes I use the named views button that I added to my right click option. click the named view and only the T/C planes are changed to that view.
    Cadcam
    Apr 2003
    3578
    PS there is an arrow at the lower left corner of the Named views window when picked it will show you all the views and you can pick the one you want to set.
    Cadcam
    Sep 2010
    135
    Larry, if I go to Gview it opens the window with lot of options... doesn't alow me to select a face without picking an option first.
    cadcam,
    Quote Originally Posted by cadcam View Post
    true but, it is very confusing, lot of views are displayed close to each other... check my attached picture, maybe Im not setting it right...
    thanks guys
    Apr 2003
    3578
    There is no option to pick a face and have it reference a all ready made plane that you made. the named views is the quick and easy way but you have to give it a reference name to help you just like giving info on levels is important. I am wondering after looking at the picture that you have that many plans for that part unless there is allot of data I am missing. Do you use the named views option to set your planes?
    Are you programming a 5axis machine or a horz mahine?
    Cadcam
    Sep 2010
    135
    if I understood your question right, to select after it was created yes, i go to name views and select it, but, to set it at the beginning I go to Planes/planes by geometry/solid and select, it creates always double view, one view with a location value set at x/y/z and other one with x/y/z set at zero...
    I'm still abit confused with this part but I am still learning...
    I'm programing 5 axis on a HMC machine. C axis seating on a B table
    Apr 2003
    3578
    Ok so you are not using the Dynamic Planes or Dynamic Wcs to set these planes.
    Sure wish I could talk to you. as I think what you are talking about is an easier way to make and set planes you want. I am in the middle programming a 5axis router my self and in the middle of teaching 5 AXIS in my classroom and about to start a new online class for it to.
    Cadcam
    Sep 2011
    [QUOTE=PRINT_FX;1123402]Larry, if I go to Gview it opens the window with lot of options... doesn't alow me to select a face without picking an option first.
    There is an option, Gview by solid face. Select the face, and if there is already a view defined, it will show that name as the current Gview.
    It occured to me just now, I'm using X5MU1, what version are you running?
    Apr 2003
    3578
    I am running X6 mu2
    Cadcam
    Sep 2010
    135
    [quote=Larry Dickman;1123510]
    I guess you are right indeed, it associates a new view to the existing one- it works indeed but why creating always a new view?
    I'm x5mu1 but in the process of installing the x6mu1
    Sep 2010
    135
    why don't you pm me with the Info for the online class? I know your work, I had purchased some CDs from you in the past.
    this project I'm working on is huge... you have no idea, months of programming time and machining- I see myself struggling with dynamic planes also because of the complexity of the project, layer, colors etc... picking the plane by geometry I only deal with the z direction.
  1. Question for previous builders.
    By nikodell in forum DIY CNC Router Table Machines
    Last Post: 04-20-2009, 12:55 PM
  2. Replies: 1
    Last Post: 04-19-2009, 08:50 PM
  3. Each pass different than the previous
    By gage1049 in forum DIY CNC Router Table Machines
    Last Post: 10-22-2008, 09:47 AM
  4. g code for repeat the previous move
    By woffler in forum G-Code Programing
    Last Post: 03-27-2008, 04:07 AM
  5. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
