So... I wanted to start a separate thread to document the re-build of this IH mill I got. I also plan on using this as a log to remind myself what I did and why I did it, so forgive a bit of rambling...
Lets start with a bit of history.
I purchased this mill (a 2005 model) used. It has very little wear.
As purchased it had the R8 spindle and stock tapered roller bearings. It also came with the NT30 spindle that was sold in the past for $65and a 2HP VFD drive through the gearbox.
My planned eventual upgrades include the following:
One shot oiling for the ways and ball screws
Tool changer
2 speed Belt drive
Max spindle RPM 6000-9000 (no gearbox)
But first tings first get it up and running and making money.
As purchased it had the following obvious issues.... first, a couple of the Z axis limit switches are broken and I could not rotate the spindle with my hand and it seemed rough with a wrench.
That last item might be due to low use but I don't know.
First item: Swap the spindle and bearings.
Instead of simply replacing the bearings with another set of tapered roller I decided to go to AC (angular contact) bearings. This will allow me to get into my 6000-9000RPM range once I swap to belt drive.
Taking the quill out of the head is fairly simple. There is one catch though... there is a set screw that limits the downward movement of the quill. You have to remove it but there is a second set screw below the first set screw (thank you Tommy).
Also, another issue I ran into is that the spanner nut on top of the spindle that holds everything together is different from the R8 spindle to the NT30 spindle. The R8 has a 1.5mm pitch while the NT30 has a 1.25mm pitch.
Another call to Tommy indicates that this is no longer the case.... off to MSC.
I wanted to take a moment to comment about IH support. I do much of my work during off hours as I have to keep a day job till things pick up. Every time I have run into an issue and have had to call IH, Tommy has picked up the phone or called me back in minutes... on Saturdays and Sundays.
I know some have had issues with service at IH but I have not. And lets remember that I have never purchased anything from them. The mill was originally a manual mill that an IH kit was put on.
I have tried to purchase something from Tommy (limit switches) only to be told to send him and email and he would give me part numbers for the parts he uses.
That is all for now!
Richard
