586,110 active members*
3,366 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > HAAS VF2 - Amplifier over Temperature Alarm
    Jun 2012
    Hello all.
    Just today, one of our machines (HAAS VF2) has thrown up two alarms.
    991 - Amplifier over Temperature
    Then followed by
    163 - Z Axis Drive Fault
    I'm not sure if it's the magnetic encoder, thermal couple issue or what. To me it sounds like the magnetic encoder bearing going out. Has anyone seen this alarm before? I'm fairly new to the machining world. Only been around these machines for just over three years. First time seeing this alarm.
    Thanks for any replies.
    Jun 2012
    Problem Resolved
    Just positing a FYI regarding the issue.
    Service tech found a stalled cooling fan to be the issue. It was an axial fan that cools the servo amplifiers. Z Axis alarm was probably due to that individual servo that was just too hot.
    Replaced fan and working great!
  1. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  2. Alarm 16 AMPLIFIER NOT EQUIPED/Mazatrol M32-6
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-28-2011, 03:02 AM
  3. Fanuc servo amplifier alarm
    By KENGLIAN in forum Fanuc
    Last Post: 02-19-2011, 03:37 AM
  4. Haas VF 3 Alarm 246
    By KartPilot74 in forum Haas Mills
    Last Post: 10-28-2010, 05:29 PM
  5. Fanuc spindle amplifier alarm 11
    By Eagle View in forum Fanuc
    Last Post: 05-15-2007, 11:10 AM
