586,416 active members*
3,950 visitors online*
    Jun 2012
    EMCO PC 50 Mill Conversion
    I was interested to see if anyone has converted this or a similar setup to linuxcnc. We got a PC 50 Mill and a Turn 55 that we would like to convert. (mostly the mill).
    I was told that you would have to rip out the motors and controllers and replace them with something newer.
    I was also told that I can just remove the original plc controller and keep the 3-phase drivers and make a new control for the drivers.
    Jun 2007
    19
    pc mill 50
    converting is no biggie..
    i have a pc mill 50 and converted it.. first to mach3 now to usbcnc..
    the pc mill 50 has 5-phase steppers not 3 phase..
    you can keep the steppers (like i did) .. and just search on ebay for berger lahr D-450 drives...
    if you have those you can hook up any controller youlike...
    as for the rest.. just buy an inverter a powersupply.. and some other small bits and pieces and your off... home switches are fitted aswhell as estops...
    pretty easy retrofit..
    Sep 2005
    1195
    Binski,
    Is USBCNC better than mach3? I mean more feature and speed.
    Sep 2005
    1195
    Binski,
    Jun 2007
    19
    Way better. You can go up to 125 khz with pulsing... Software is more stable better user inteeface and dedicated hardware..
  1. Emco F1 conversion
    By slow_rider in forum Benchtop Machines
    Last Post: 11-27-2022, 03:38 AM
  2. Advice on conversion of Emco Unimat PC
    By alpinasjofallet in forum Benchtop Machines
    Last Post: 08-09-2011, 12:59 PM
  3. Replies: 2
    Last Post: 05-10-2008, 06:32 AM
  4. Emco PC 5 Conversion
    By Nigel_B in forum Australia, New Zealand Club House
    Last Post: 10-23-2006, 10:38 AM
  5. Emco f1 mill conversion help
    By no1uno in forum Benchtop Machines
    Last Post: 11-10-2004, 09:58 PM
