586,123 active members*
3,458 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 5 axis breakout, TB6560 driver, 6 wire stepper
    May 2012
    A 6wire unipolar stepper + 5 axis breakout board + TB6560 single driver what I like to connect together (the 5 axis and TB6560 I bought on ebay, and the motor is unknown).
    Is it correct connection:
    TB6560 driver and 5 axis breakout: -CLK to GND. -CW to GND, -EN to GND, +CLK to XS, +CW to XD, +EN to XE
    And the motor:
    black-brown, black-yellow 6ohm; yellow-brown 12ohm
    blue-red, blue-green 6ohm; green-red 12ohm
    If I'm testing the motor with +power to the black and blue.
    And -power to the brown, green, yellow, red then the motor stepping one-way.
    But If I try to give power : +A brown to -A yellow, +B green to -B red then the motor just step 1 forward and 1 back or sometimes just maybe half step. And it's doesn't matter if I change the wires + to -.
    Is it normal or I'm doing something wrong here?
    Thanks for trying to help and sorry for my English.
    May 2012
    Yep it's ok !! Why not?!
    All my problem was with the Mach setting..
  1. 3 Axis TB6560 CNC Stepper Motor Driver Problem
    By Overminde in forum CNC Machine Related Electronics
    Last Post: 05-23-2012, 11:09 AM
  2. Problem with CNC 4 Axis 3.5A TB6560 Stepper Motor Driver Board
    By bbbharvard_cnc in forum CNC Machine Related Electronics
    Last Post: 04-10-2012, 06:11 AM
  3. 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    By RCjunkie in forum CNC Wire Foam Cutter Machines
    Last Post: 01-24-2012, 04:45 PM
  4. TB6560 4 Axis CNC Motor Stepper Driver 3A 12-36V
    By vicsrc in forum Want To Buy...Need help!
    Last Post: 03-10-2011, 05:57 PM
