586,035 active members*
3,648 visitors online*
    Jan 2011
    171
    Helmet builder
    I build wood helmets. Yep. You can check em out at Coyle Treepieces.
    Anyway, I build them on a leased Shop Sabre with a 7 hp spindle and 7 inches of travel. I need to build more, faster and am shopping for something with higher capacity. I have a year of CNC routing under my belt but no professional background so I am looking for any feedback that can be offered. I understand only some CNC jargon and rely on the guy I lease from to figure out most of the stuff related to the CAM software, controller etc. I would like to get something with two or three heads (or something that can handle this). Generally I am using big bits (1.25 inch diam. right now) to hog out blocks of hardwood that are 12"x10"x7"(deep). Takes nearly two hours at 100 - 150 IPM on the current setup (12K RPM). My assumption is that I want a heavy steel frame, and a lot of horse power and rigidity. I would love to cut a couple,three helmets at a time at 300+ IPM.
    Anyone have experience with fast/large material removal applications and what would work best?
    Nov 2007
    2466
    i have a digital 905 with 4 heads in unison, there are others as well, camaster makes a simutanious or autonomus twin atc tool changer for a well known Guitar manufacturer, go see it in GA as this one is about to be delivered, there are others on order
    thre are some vids of this baby in action
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Nov 2007
    2466
    Dec 2020
    Re: Helmet builder
    Always buy Dot Approve Helmets ---- https://helmetbest.com/ -----
    Feb 2021
    Re: Helmet builder
    If you are looking for highly durable helmets of any category then you can visit https://helmetadviser.com/ and save your time.
  1. Firefighter helmet
    By HarleyGirl in forum PlasmaCam
    Last Post: 05-12-2021, 07:19 AM
  2. Metal helmet clip cnc job.
    By Snaky23 in forum EUROPE RFQ's
    Last Post: 03-30-2013, 12:27 PM
  3. Helmet Visor Questions?
    By frogger in forum Vacuum forming, Thermoforming etc
    Last Post: 04-26-2010, 10:38 AM
  4. Welding Helmet (video)
    By Switcher in forum Welding Brazing Soldering Sealing
    Last Post: 06-23-2007, 02:13 AM
