Hi all,
Well I have just started my steel frame build. A couple of years ago i made a bad first attempt at a small machine that ended up with a pile of metal and a chinese controller board that did not work from the day it came out of the box.
So lesson learned I have decided to build a bigger and hopefully better machine with a steel frame and decent electronics.
So after considering importing a chinese machine, then looking at a CNC Router Parts kit (the freight to Australia was a killer) I then looked into a T-slot frame and finally settled on a steel frame which will probably have a T-slot gantry.
- The frame is 65*65*3mm primed steel tube
- The rails are 20mm supported round rails - I bought them from AusX mods, chris has been fantastic help.
- Two ball screws on the X (gantry axis)
- one ball screw on both Y and Z axis
- Stepper motors NEMA 24 495 oz on X and Y axis - 387 Oz on the Z axis - Aus X
- Gecko G540 controller AusX
- 2.2kW chinese water cooled inverter.
- Table size 1200*1400mm which should give me approx 1000*1200. With an overhang at one end to allow for dovetail joints
So my first bit is the bed, i am a bad welder and after reading MadVacs build log decided that avoiding warping due to weld heat would be a good idea.
My solution is to position the parts flat and square on the floor then epoxy (JB weld) a 50mm*3mm flat steel plate across the joints.
When the epoxy has hardened (min 24hrs) I drill and tap straight through the plate into the frame. Flip the frame and repeat on the other side - refer pics.
So far so good the epoxy is amazing stuff.
I hope to get the frame fairly accurate with the key issue being parrallel rails and the bed parrallel to the rails. My final step will be to machine the MDF bed flat
One issue I am having is finding a supplier of 1mm2 4 core shielded cable - does anyone know of any in Aus?
Apart from that I am content with progress so far, but would welcome any feedback.
Rich
