I have developed a Mach3 plug-in for a USB based I/O board and require field testing of the plug-in.
I would appreciate someone's help from Canada or the US to install and test the operation of the board, plug-in, USB driver, setup instructions, and documentation. I will provide the breakout board and wiring harnesses for free, but you would have to take care of the shipping-related costs.
The USB I/O breakout board is compact, has 16 inputs and 10 outputs: all I/O are solid state DC. The outputs can directly drive large solenoids, relays, contactors, lamps etc, are surge and over-current protected, and can handle up to 2A/24VDC. The board uses Molex connectors for field connections, and I will also provide 2 ft long wiring harnesses.
We've been making this board for two years, and it has been extensively tested and currently in use in a non-Mach3 (Windows CE) OEM heavy-duty machinery application, so the board hardware has been found to work properly and to be reliable even in harsh conditions ... it's the Mach3 plug-in software that is new and that requires testing and user feedback.
If you are currently working on a Mach3 application, require additional I/O, are an experienced Mach3 integrator or user, and you can test and review the plug-in, please first read the information about the board at this blog post , then send me an email or PM providing ome information about your application.
I would like to have the testing completed in June if possible.
Thanks in advance,
Frank
