586,426 active members*
3,024 visitors online*
    Mar 2008
    81
    Question Enable/disable
    Hello people,
    I'm building a machine and am going to run emc/linuxcnc.
    what my question is, is i have most of the code worked out and everything but i'm building a 4 axis (evently) machine that will probally mainly do 3 axis work.
    What i require is is there anyway to use the enable/disable pins on my motor driver board via emc/linuxcnc to either drop the 4th axis for 3 axis work or enable it for 4th axis work if i need and if so what is the code i should use for this if any or if i should just use a manual switch to do this.
    Thanks for your help or information
    William
    1943
    If it were me, I would just create 2 separate machine configurations. One a 3 axis and the other a 4 axis. Just pick the config you need at start up
  1. 4th axis disable/enable
    By davesnd in forum Fanuc
    Last Post: 07-04-2023, 08:38 AM
  2. VSD-A Disable Pin
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 09-01-2011, 11:58 PM
  3. Enable and Disable Backlash Adjustment
    By HackMax in forum Mach Wizards, Macros, & Addons
    Last Post: 09-24-2009, 01:54 AM
  4. How do you disable SMI?
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 03-04-2009, 10:22 PM
  5. Disable switches
    By swarfmacdaddy in forum Gecko Drives
    Last Post: 10-24-2007, 08:28 AM
