Why will the phenomenon of tool bound occur?
1. For the curved surface of cnc wood router with comparably large height difference of engraving, you must firstly try to move the spindle motor up and down. Ensure that there will be still a certain allowance from Z-directional guide rail to the maximum limit location when the tool is at the maximum point of the curved surface, or else, it will probably be withheld for the upward movement of Z-directional guide rail has exceeded the maximum movement range, and after that, all the graphs will be moved down for some distances, causing the tool of cnc wood router to be bound.
2. After the workpiece engraving completes, it should automatically execute the end directive for the file output. The tool nose will be raised to 3.75 mm above the surface of the workpiece, when the Z coordinate of the tool nose is at –100. If it 10 sends the directive for the next graph, the tool nose will conduct deep cutting according to the correct depth. If the maneuver control box of cnc wood router locate the tool hose at the workpiece’s surface, please be sure to reset once before again outputting graphs, or else the tool hose will firstly lower 3.75 mm for the current location (The software believes that it currently only reaches Z = 0, i.e. the workpiece surface.) before setting to the defined depth to engrave, thus causing the tool of cnc wood router to be bound.
