Ok... I picked up a little router recently. It claimed some stupidly fast rapids for its size and build. Amazingly it can do them on X and Y as long as nobody opens the shop door and changes the air presure in the shop suddenly. LOL. Seriously its lamely underpowered. Has a Nema 17 on the Z that even with the light weight handpiece they setup as a spindle struggles when going up. I suppose with a different controller and different power supply it might be better, but it came home to me how lame it was when I blew a fuse. The power supply, spindle and controller all run through a 2 amp fuse.
So... I am borrowing the motors and controller of one of my other machines to see if I can't get a little better performance out of it. I don't have (or want to have) any other NEMA 17 steppers besides that one that was on the Z so I have to modify that axis atleast for a Nema 23 motor. They have the Z axis motor hanging down behind the gantry driving the Z ballscrew with a belt and pulley setup. If it was a gear reduction I would understand that given the dinky motor, but its a straight one to one. I can modify the mount easy enough to use the same pulley and mount the motor in a similar manner, but I could just as easily use some spacers and mount motor above the end of the screw with a helical coupler making a direct connection.
Other than the fact that the machine will be taller is there any reason to put the stepper motor behind the gantry using the belt drive as opposed to directly over the screw using a helical coupler? The Y & X on this machine both use direct helical couplers.
Both of my little desk top mills have the Z stepper right up on top directly connected with a helical coupler to the Z screw and they work just fine.
