586,119 active members*
3,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Coolant Water in my Hydraulic Oil Main Tank???
Results 1 to 6 of 6
    Oct 2008
    13
    Why is there coolant water in my Hydraulic Main Tank??? I noticed last week that my coolant water kept getting low too quickly. As I looked for the water leak I noticed that my Hydraulic Oil Tank was what seemed to be over-filled. I drained it a bit and what came out was mostly water...
    Hitachi Seiki Hitec-Turn 25M...
    Jan 2006
    2985
    Where do the two systems cross paths? Maybe a corroded heat exchanger that is leaking? Bad gasket somewhere? Hard to say without knowing the machine.
    Matt
    Feb 2009
    6028
    Coolant is going down the spindle tube, it's overfilling the water return box, and sucking into the return of the hydraulic actuator for the chuck.
    Oct 2008
    13
    Quote Originally Posted by underthetire View Post
    Sounds like it could be happening... I am machining smaller parts where the coolant is almost shooting into the spindle hole... I will try to temporarily plub is with a sponge or something to see if this resolves this issue while we machine these parts...
    Oct 2008
    13
    Quote Originally Posted by keebler303 View Post
    Matt
    Thanks Matt,
    I hope that this is not the issue... We might have to contact the mechanic if plugging the spindle hole does not help...
    Oct 2008
    13
    "Underthetire"... Thanks for the post. We cleaned out the water return box & hose and the problem was fixed...
    Gamy R.
  1. Water Heater Tank preparations??
    By LukeA in forum Vacuum forming, Thermoforming etc
    Last Post: 10-23-2013, 10:17 PM
  2. Water Jet catcher tank cleaning
    By u2tree in forum Waterjet General Topics
    Last Post: 04-01-2009, 01:51 AM
  3. Jsm40U water tank and ducting
    By James80 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-26-2009, 06:14 PM
  4. water table level control using air tank.
    By Fiero Addiction in forum Waterjet General Topics
    Last Post: 03-25-2008, 10:45 PM
  5. plasma water tank
    By snaggletto in forum Waterjet General Topics
    Last Post: 06-17-2006, 01:04 PM
