586,075 active members*
3,678 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Adaptive Roughing Sample
Results 1 to 7 of 7
    Mar 2012
    1570
    So if you don't know V25 now comes with Adaptive roughing, this is a 3D High Speed tool path. This can be a great tool path to rough out 2D & 3D parts.
    In this example we want to use the Adaptive Roughing to clear out most of the stock on the pockets.
    gif hosting
    Adaptive Roughing Sample:
    hosting images
    Here is a quick video walking through the tool path setup.
    HSM Sample - adepoalo's library
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    HSM Sample
    Here is the sample file I used in case you want to try it on your own : )
    Attached Files Attached Files
    Al DePoalo
    Apr 2009
    3376
    Al your Freakin me out.You reading my mind?????:idea:
    Mar 2012
    1570
    Working from the out side in
    Here is another example of how you can use the adaptive roughing
    gif hosting
    Al DePoalo
    Mar 2012
    1570
    100 % step over
    Another nice feature on adaptive roughing is you can use 100% of your tool.
    This image is a standard offset pocket.
    free picture hosting
    Nothing wrong with it, just that where would be stand ups left because the step over is greater than 50% off the cutter.
    This image is the adaptive roughing using 100% of the cutter
    image upload
    You can see how it will clean all the material with a smooth cutting motion!
    Al DePoalo
    Jun 2012
    514
    being really new to adaptive...could you pout this in simple terms...and explain what it is...sorry for being clueless.
    Dec 2011
    361
    Adaptive Roughing is a feature that is a high speed roughing option. Instead of using any straight line cutting movements, it uses arced movements to allow more contact per pass with the tool, allowing for a quicker roughing cycle. Think of it as a 3D Roughing HSM.
  1. Advanced/Adaptive Roughing
    By jrmach in forum BobCad-Cam
    Last Post: 06-02-2012, 03:09 AM
  2. Adaptive milling fixture help
    By HAMMER66 in forum Canadian Club House
    Last Post: 01-08-2008, 02:31 AM
  3. adaptive feedrate
    By camtd in forum EdgeCam
    Last Post: 11-13-2006, 11:59 PM
  4. Researchers for Adaptive Clearing wanted
    By goatchurch in forum Uncategorised CAM Discussion
    Last Post: 03-22-2006, 07:13 AM
