586,108 active members*
3,238 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > X- axis lag adjustment
    Jun 2012
    Help!! Does anyone know how to adjust the x- axis lag on a 1991 Tree 325. It has MSI Motor Drives and it has been a really great machine for us.
    Feb 2009
    6028
    The balance pot on the x axis card sets standing lag, should be as close to zero as possible. The tach pot adjust moving lag. Pots are labeled on the board.
    Jun 2012
    OK thanks for the input, but I am not sure which one to adjust. There are 6 different spots to adjust on that board. Top to bottom they are listed as;
    YC , SG , BL , RC , PC , TG.
    Any idea??
    Oct 2006
    106
    I'm more familiar with the Servo Dynamic drives, but I'll take a swag:
    YC - don't know
    SG - Signal Gain (Command Voltage Input Scaling)
    BL - Balance
    RC - Compensation
    PC - don't know
    TG - Tachometer Gain
    If you're happy with how the Y axis is working, I would suggest that you adjust the lag on the X axis to match Y. I think you'll find that you can adjust the lag by moving the SG pot.
    Balance (BL) should be adjusted with the axis at rest. You're looking for a lag amount of zero, but there always seems to be +/- .0001"
    Feb 2009
    6028
    Quote Originally Posted by jagardner4 View Post
    YC - don't know
    BL - Balance
    RC - Compensation
    PC - don't know
    Swing and a hit.
  1. axis lag adjustment
    By garychipmaker in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-15-2011, 05:13 AM
  2. NM-135 Y-Axis Adjustment
    By StillLearning in forum Novakon
    Last Post: 02-25-2011, 04:27 PM
  3. z axis gib adjustment
    By bjm323 in forum Taig Mills / Lathes
    Last Post: 03-22-2009, 04:34 PM
  4. z axis adjustment help
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 05-01-2008, 07:38 PM
  5. IH axis adjustment
    By Shepard in forum Charter Oak Automation Support Forum
    Last Post: 03-27-2007, 03:45 PM
