586,395 active members*
2,747 visitors online*
Results 1 to 6 of 6
    Jun 2012
    18
    Exclamation Choosing Shafts for linear motion
    Hi all. I am designing a CNC 1st time and need help with choosing shafts for linear motion. I am stuck between these sizes:
    1) Shafts having diameter of around 16/18mm
    2) Shafts having diameter of around 10/12mm
    Is using shafts of bigger diameter , for linear motion support , better and stable ?
    I will be using open type linear bearings(with housing) with those shafts. My total X Axis length is 500mm and Y axis about 400mm.
    Aug 2008
    409
    Are those supported shafts?
    Thicker is better.
    Jan 2006
    2985
    Supported shafts will give you a much better result and the bigger the better.
    Matt
    Jun 2012
    18
    Exclamation
    Quote Originally Posted by Phife View Post
    Thicker is better.
    I am planning to use shaft support rails and hence will be using open type linear bearings. I plan to use shaft end support blocks and linear support rails. But I am confused about how the shaft it attached or mounted on the support rails.
    Any help on that will be much appreciated.
    Jan 2006
    2985
    Normally supported rails are purchased that are already drilled and tapped or are already mounted to a base rail, like this: http://www.thomsonlinear.com/website.../multitrac.php
    Matt
    Aug 2008
    409
    heres another example of supported rails, I dont recommend you try and drill/tap your own rails as its not an easy job to do..
    Glacern Machine Tools - Linear Rails and Bearings
  1. Is this span ok for 20mm linear shafts? (see pic)
    By RMS in forum Mechanical Calculations/Engineering Design
    Last Post: 01-11-2011, 02:46 PM
  2. Replies: 0
    Last Post: 11-06-2010, 07:15 AM
  3. Choosing linear motion system
    By Jesse B in forum DIY CNC Router Table Machines
    Last Post: 01-11-2010, 01:54 AM
  4. linear rails VS shafts
    By axkiker in forum DIY CNC Router Table Machines
    Last Post: 02-08-2008, 04:36 PM
  5. Linear Shafts...
    By WilliamD in forum Linear and Rotary Motion
    Last Post: 01-19-2006, 07:23 PM
