I am looking to make round holes (bolt holes) 3/8"-3/4" in mild steel.
At Northern Tool they have a Torin 31 ton Hydraulic Hole Punch, does anyone have any personal experience with one of these units?
Thanks for any info.
What gauge mild steel?
Is this for production?
If small quantity, Greenlee have a manual electricians Hyd. punch set, you can get the dies in various sizes.
Al.
Albert E.
I knew I forgot something, 3/8" mild steel. Small production, this will not get daily use.
No, look at the q and a page. 1/2 inch hole max 3/8 thick. I doubt it could even do that through steel.
Hey underthetire
Thanks for the reply.
I want to make sure I am reading the same thing you are, from the Q & A:
Question-"Can this unit punch a 1/2" hole in 1/4" copper"
Answer-"This hole punch can do a 1/2 inch hole but only through sheets that are 3/8 inch thick or less." I think the Answer customer service person is looking at the specs and referring to the spec on steel, not the specs on copper.
Is this the Q & A you are referencing?
Does anyone have any personal experience (HANDS-ON experience) with this unit?
Just a rough calculation shows 3/4" hole in 3/8" will work OK with 31 ton with just a 10% margin.
Any thicker, or a bigger hole will fail.
The second chart looks quite easy to use, and the numbers make sense.
Punching force calculation
http://www.anvilfire.com/21centbs/ma...hing_steel.htm
neilw20-
Thanks, the second link's info is very clear.
