Originally Posted by
sexton
Shut my TM1 off Friday night around Nine. Saturday morning hit the power on button, got the usual BEEP,screen tries to come on but doesn't, then the spindle load meter starts pulsing from zero to sixty percent. No buttons on the control panel work. Tried rebooting, same result. Opened the bac and tried to boot again, a whole bunch of led's on a whole bunch of boards are pulsing on and off just like the spindle load meter. The three red led's on the board close to the power supply blink on and off, all the other led's on other boards are green and blinking. The fans located under the servo amps. are running constant not pulsing on and off like the led's. My machine is wired up to run one phase and I checked the voltage coming into and out of the machine breaker and it shows ok.
Anyone ever have a problem like this?
Thanks in advance.
That sounds just like a problem I had with my work computer. At times I would turn it on and it would not fire up but sit and pulse on and off with the visible LED's (power button, USB drive and disk drive LED)
On it it turned out to be the power supply had gotten dirty and it was shorting (like static discharge) internally and was shutting itself off and on.
Try going to the power supply and blowing air into it (with the power off of course) then try to start it.
It does sound like it could be the power supply anyway, whether or not that works. The power supplies are basically identical.
Mike
