Originally Posted by
torinwalker
I'm trying to find a suitable replacement blade for the AHC-13 tool holder on my cross-slide (CHNC-1). If you are using an indexable cut-off blade in your cross-slide can you post the make and model, and whether you had to modify the tool holder?
The original is a G21 Belcar-Hardinge indexable blade, p/n 68A-0009639-03, but I can't find a compatible replacement with the same dimensions. I see a Belcar P-X5 that is very close, but there are no dimensions in the Belcar catalog for this blade. I've emailed them and received no response.
I also see an Iscar SGFS SELF-GRIP blade, but either the width is a fraction too thick, or the angle isn't right.
I'm buying a blade for this holder for the first time. Perhaps they're more flexible (with the blade width) than I realize?
Any help is greatly appreciated.
Torin...
